Modular V10 (6.8l)
Engine making a weird sound?
Old Feb 15, 2004 | 04:40 PM
FX4man03's Avatar
FX4man03
Exclamation Engine making a weird sound?
I just went out and bought a 2000 F-350 w/ V-10..i test drove it and everything worked out fine. It has about 33,000 miles on it. I am now hearing a weird sound that is comming from the engine compartment. It only happens when you start to get on the gas. if the truck is in neutral and you rev the engine it will not happen. it sounds like machine gun going off but much softer in sound. should i just take it to the dealer and let them look at it? Any info would be great thanks!
Old Feb 16, 2004 | 11:30 AM
Big Orn's Avatar
Big Orn
Do a search on "flutter" in this forum and see if this is similar to what you hear.
If not, try and give us a little more detail.
Old Feb 16, 2004 | 03:56 PM
HeavyAssault's Avatar
HeavyAssault
Any particular RPM that this happens??
Old Feb 16, 2004 | 07:38 PM
FX4man03's Avatar
FX4man03
it usually happens around 2500-3000..i am taking it back to the dealer so i will see what they say
Old Feb 16, 2004 | 10:46 PM
68 351 bronc's Avatar
68 351 bronc
FX, If you have an auto tranny than it is probably the torque converter dust cover. located on the front of the tranny. The aluminum cover rattles. On this site it is called a flutter.
Old Feb 16, 2004 | 10:48 PM
68 351 bronc
Fx, also I don't think there has been a service buletin issued on this so the dealer may or may not be able to help you.
Old Feb 17, 2004 | 04:14 PM
FX4man03's Avatar
FX4man03
ok thanks for the info...I will check that out and see if that is what is causing the noise..the truck still has to go back because it is leaking oil where the drive shaft hooks up to the gearbox...I think the seal went bad
Old Feb 21, 2004 | 08:15 PM
Dwinn's Avatar
Dwinn
I have a 2000 F250 SC LB 4x4 V10 and had three noise/vibration problems. The first was when I would hit the gas and the engine would go up to around 2,500 - 2,800 rpm. It sound like an exhaust leak. I went to the dealer and they said their was a tech bulletin about the 2000 and older Y pipe. They fixed it at a small price and the problem went away. The second was one of the baffles inside the muffler started vibrating around 2,000 rpm. Replaced the muffler and that problem went away. The last one, I fixed today, was the thin metal torque converter cover on the front of the tranny (two bolts). It would vibrate around 1,900 rpm. I posted how I fixed this in the V10 forum (a little velcro).
Old Feb 21, 2004 | 10:10 PM
Monsta's Avatar
Monsta
Sit. Stay.
On this site it is one of the causes that could create a sound that is confused with "flutter".
Old Feb 21, 2004 | 10:36 PM
68 351 bronc
Ken S. could you give us more information on what a flutter is?
I thought it was the auto tranny rattle.
Old Feb 22, 2004 | 06:48 PM
Shepard's Avatar
Shepard
I went through a frustrating time last year trying to determine exactly what the flutter sound is. In the end I could not learn anything definitive. My sound occurs only between 1700 and 2000 rpm, more commonly about 18 or 1900. It is more a fluttering pressure sound that affects your ears, rather than the sound of something rattling as some have described. Similar, but much less and not exactly the same kind of pressure you might hear if only one window was open a bit on the highway.
Old Feb 22, 2004 | 11:40 PM
68 351 bronc
shepard, so have you checked the aluminum cover on the front of the tranny? It worked for me!!
Old Feb 23, 2004 | 12:39 AM
Monsta's Avatar
Monsta
Sit. Stay.
Flutter: A sound made within the exhaust tubing caused by exhaust pulses colliding with each other at the Y-pipe.
Ford "fixed" this by "necking down" the passenger's side pipe where it meets the driver's side. This "necking down" created a difference in exhaust velocities enough to eliminate the sound.
Many know that this "necking down" also hampered performance.
Old Feb 26, 2004 | 06:37 PM
FX4man03's Avatar
FX4man03
Ok.. I found out from the dealer that the noise i was hearing was an exhaust leak..so they are going to fix that for free..thanks for all your info!
Padlock
Aug 26, 2014 08:04 PM
Deadsquiggles
1978 - 1996 Big Bronco
13
Jul 2, 2014 10:42 AM
King Kerosin
Dec 4, 2013 11:13 AM
AndeyHall
Apr 15, 2011 11:13 AM
F 250 6 liter
Jan 18, 2011 01:06 AM
