Offroad & 4x4
Another crossover steering question
Old Feb 15, 2004 | 01:32 AM
ivanribic's Avatar
ivanribic
Just reading through some posts on steering and had a quick question. What is the difference between regular crossover and hi-steer crossover? If anyone has pics or links that would be great since I'm mentally challenged and have a hard time visualizing anything.
Also, what are advantages to one over the other?
Ivan
Old Feb 15, 2004 | 02:26 AM
77'F-150Mudder's Avatar
77'F-150Mudder
I think I might be able to answer that.
A regular X-over steering system will have the tie-rods bolted to the bottom of the stock steering arm, like stock. I'll pimp a pic out of Pro's x-over gallery so you can see what it looks like. Thanks Pro.
Some do a pseudo high steer by doing a little reaming on the stock arms, and then bolting the tie-rods on from the top. The extra couple inches of clearance is the payoff.
In general, a true high steer uses custom steering arms bolted to the top of flat top steering knuckles. This moves the tie-rod above the leaves and gets it pretty much completely out of harms way. If Pro's system was high steer you'd see the tie rod bolted to the same arm as the drag link.
Anyone feel free to correct if you see any holes on my explanation.
Old Feb 15, 2004 | 12:23 PM
proeliator's Avatar
proeliator
Nope, ya done good Hi-steer x-over is typically done over a simple crossover if: A) you need adjusted angles for optimum leverage, or B) you need the additional clearance.
I didn't need either so kept is simple.
