fuel problem with 99 xls
Old Feb 14, 2004 | 11:54 PM
jdelta20's Avatar
jdelta20
Question fuel problem with 99 xls
OK, There seems to be alot of people here with fuel/pump problems.....I have replaced PCM, fuel pump, fuel filter, relays and tested inertia switch. I can turn the key on and my fuel pump only comes on for half second or so, not 3-5 seconds......it will turn over but not start, I can spray a little starting fluid and it will run until the starting fluid is used up...what am I missing? Could use some help with the phantom problem
Old Feb 16, 2004 | 02:13 PM
77redf250's Avatar
77redf250
check the wiring connections around the pump may be a loose ground or voltage drop in power wire . there might be just enough voltage to kick the pump on but not enough to run it once pressure builds
fordf1501991
19
May 30, 2019 06:32 PM
TheBlueMule
Apr 11, 2014 10:50 AM
stirkrazy
Jan 11, 2009 07:56 AM
dadrich67
1978 - 1996 Big Bronco
15
Feb 20, 2008 07:03 PM
