rust
Old Feb 14, 2004 | 11:27 PM
valo's Avatar
valo
rust
need help with a rust problem Bought my ranger 1 month ago noticed rust around the gas filler neck. My drive shaft also has a coating of rust should i worry about this or is it a regular problem. Ran a carfax it came up clear.What can i do to get rid of this problem. only has 31000 miles on it
Old Feb 15, 2004 | 05:09 AM
Dealford's Avatar
Dealford
Welcome to FTE valo.
First, take the truck to your bodyshop & get the exterior fixed. As soon as that's done, have the truck oil sprayed.
Or, let it go & watch your investment rust away.
Old Feb 16, 2004 | 03:45 PM
Ken00's Avatar
Ken00
The rust coating on the driveshaft is OK.
Old Feb 16, 2004 | 07:21 PM
valo's Avatar
valo
oil spray
thank you for your response. Can you please explain to me what is oil spray and what will it do to my truck
Old Feb 16, 2004 | 07:55 PM
Dealford's Avatar
Dealford
Proper oil spray oil has a rust inhibiter in it. If you can find a local outfit that will show you the barrels of product, it will be "stenciled" on the top "contains rust inhibiter".
Used engine oil has alot of combustion by-products in it making it a bad choice.
There are 2 main retail rust proofing outfits (oil spray) here in Ontario. Rust Check and Krown. This should be done at least every other year or twice a year in high salt conditions.
Old Feb 16, 2004 | 08:05 PM
valo's Avatar
valo
thanks for the info. I live in the high desert of So Cal. So not to much of a salt problem here .But i will look into getting that rust repaired.
