General Automotive Discussion
when to use offset wrench
Old Feb 14, 2004 | 09:28 AM
carpe_diem's Avatar
carpe_diem
Exactly in what instances do you use an offset wrench?
I never used one. But I am thinking about changing the O2 sensor on this F250 and the regular open end wrench will not fit in there, you need something curved. I also don't want to use a socket because these special O2 sockets easily bend (I've bend one before)
So I need a special 7/8" offset wrench.
I think I could also use a 7/8" deep socket taking it out but I would have problems putting it in because of the sensor wire.
Old Feb 14, 2004 | 12:16 PM
RexB's Avatar
RexB
An offset wrench will work if there's enough clearance to fit its 'socket' around the stuff next to your O2 sensor and still turn it. A single 7/8" wrench might be a little pricey- maybe you have an old one you could heat and bend to the needed depth/shape.
A 'claw-foot' wrench-end (fits on the end of a socket extension bar) might fit in there instead.
Old Feb 14, 2004 | 12:26 PM
rebocardo's Avatar
rebocardo
There are special sockets just for o2 sensors. Depending on the sensor, they can come with rounded corners, cut outs for the wire harness, special detents, etc. I just buying a KD or major brand socket made for the sensor. It is money well spent. Especially if you have to use an impact socket.
Old Feb 14, 2004 | 06:24 PM
cwb's Avatar
cwb
I have never used them either. I have used the specialized sockets, thoug and they work perfectly.
Old Feb 15, 2004 | 11:37 AM
rebocardo's Avatar
rebocardo
> I just buying a KD
That should have been "I would just buy"
Old Feb 15, 2004 | 12:44 PM
DragTruckin's Avatar
DragTruckin
header bolts! those are a pain without an offset wrench!
Old Feb 22, 2004 | 02:36 AM
carpe_diem's Avatar
carpe_diem
I think I need a quality O2 sensor socket which will not bend. I got one from Advanced Auto parts and to my horror discovered I was bending it and not loosening the socket. ('this on a chebby)
I returned it, got a regular deep 7/8" socket, cut the wire, fit it over it, and that was it.
On this Ford, a special O2 socket would work better than any wrench but I fear that it has seized in there sufficiently where I will again bend the lips of the socket apart.
O2 sensors get *very* stuck, especially after 150K miles. PB-blaster helps - somewhat.
Old Feb 22, 2004 | 01:00 PM
rebocardo's Avatar
rebocardo
Actually, applying heat until it is cherry red helps the best. On one that is stuck, an impact socket works best because it is six sided and the walls are thick enough that it will not deflect under pressure, unlike a thin wall socket.
An impact, forwards and backwards, will break it free pretty quickly. You just have to be sure you do not rip the bung out of the pipe, I hate when that happens.
Old Feb 22, 2004 | 07:56 PM
hreed's Avatar
hreed
The best time to use an offset wrench is when that is the only tool that will fit the bolt/nut you need to tighten/loosen.
Old Feb 25, 2004 | 11:08 AM
carpe_diem's Avatar
carpe_diem
That makes perfect sense. I have been doing minor tune up kind of work for a decade but only had a few instances (1 or 2) where I needed an offset wrench. But when you do, you really need it with no substitute.
Old Feb 25, 2004 | 09:59 PM
hreed's Avatar
hreed
There are times and places that the only tool that will do the job is an offset wrench. Just be prepared to spend a lot of time because you can only get 1/8th of a turn each time (if you are lucky), and you have to turn the wrench around each time.
Emsand1
May 15, 2016 10:45 AM
LeoJr
Nov 14, 2013 08:15 PM
eigenvector
1983 - 2012 Ranger & B-Series
May 2, 2010 02:03 PM
Munkey
Garage & Workshop
18
Mar 9, 2005 06:15 PM
BigJake86
Apr 25, 2003 12:23 PM
