light
Old Feb 14, 2004 | 01:09 AM
robertleeii's Avatar
robertleeii
light
my right blinker does not work changed the bulbs out top and bottom doesent help. wonder ing if any one has an ida on how to fix it
Old Feb 14, 2004 | 01:33 AM
96P_Stroke4x4's Avatar
96P_Stroke4x4
Smokin'
you should check all the blinker bulbs, front and rear, and also the 3rd brake light. a shorted out bulb could cause that, or is it just the interior blinker indicator bulb thats out?
Old Feb 17, 2004 | 05:32 AM
77redf250's Avatar
77redf250
did you check the fuses?? i've replaced a few multifuntion switches(signal,wiper) to fix this problem. do the hazards work? try smacking the top of the steering column with the blinker turn on this is the speedy way to diagnose it.
