Crane cam question
Old Feb 13, 2004 | 06:54 PM
Annihilator's Avatar
Annihilator
Crane cam question
I need to go buy the a Dyno program (either Dyno Sim or Dyno 2000 whichever I can get at Walmart) but I was looking at 2 Crane grinds at the moment and they are the CRN-343901 and the 343941. Was just wondering if the second one with a lift of .533 Intake and .563 exhaust would be getting a little 2 up there for stock rocker-shafts and stands (adj. rocker factory type). I wouldn't think so and I wouldn't probably ever take the engine over 5200-5500. My valvetrain is all new.
I am looking into the 2 I mentioned along with the Energizer CRN-134052 grind. Has anyone here ran any of Lunati's, Isky, Engle, or Erson's grinds and thought they had good cams for the FE?
I can't find any info on Erson and Isky (have been to Isky's website but nothing listed for FE). I still am thinking about a custom grind too but I guess we will see.
Old Feb 13, 2004 | 10:21 PM
Ratsmoker's Avatar
Ratsmoker
Gimme your engine specs and I will tell you what Dynosim says. The 941 will be about the max I would run with stock stuff. I broke 2 shafts with my 801 and stock shafts and stands with adj rockers.
Old Feb 13, 2004 | 11:17 PM
stephenw's Avatar
stephenw
I ran the 343941 Crane for nearly 70k miles on a 390 engine with otherwise stock valve train, no problems, and it's still sitting on a stand if I ever have need to use it. Now have new 343941 with DSC adjustable valve train on my 410, no worries. Dennis at DSC didn't think there was anything to bother about either, JFWIW. I do subscribe to the notion that it's reaching the upper limits however.
Steve
Old Feb 14, 2004 | 12:37 AM
Ratsmoker's Avatar
Ratsmoker
That makes me feel better about the statement I made. Its always nice to hear from someone that has actually run one.
Old Feb 14, 2004 | 06:43 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Hey Stephen!!! What did your 390 idle at with the 343941 crane cam in it?? and what kind of lope does have??
I would like yo run one on my 390/stock converter/C6
Old Feb 14, 2004 | 09:44 AM
stephenw's Avatar
stephenw
Seems like Crane says it has a "good" idle, and I would agree with that. It was pretty smooth at about 650 rpm but had enough of a lump to let you know it wasn't "quite" a grocery-getter.
Old Feb 14, 2004 | 10:56 AM
RapidRuss's Avatar
RapidRuss
Thanks Steve...And you had know problems running it with stock heads??
I just Bought the Edlebrock RPM manifold...I was going to go with Edlebrock RPM heads?? But I do have the 406 heads I can Port match??
I also am running Hedman Full Length Hedders... into full Length duals out the sides..behind the rear tires..Ihad a camper on it..
Also a 750 holley on top... Elec..choke... And I do have an equilizer Tube on the hedder system...
I just bought the DUI..Dizzy!!! Big Ford plug wires...I hope that will get me too at least 350 HP??
Ratsmoker...Help!! before I make any mistakes!!! can you run this on your Dyno?? Plaese!!! Any responce on this ...set up..would be very HELPFUL!!! Thanks Guys!! and FTE!!!!
Old Feb 14, 2004 | 11:01 AM
gtex's Avatar
gtex
Let me know what you think of the DUI. Another vote of confidence and all the MSD stuff goes up on Ebay!
Old Feb 14, 2004 | 11:15 AM
RapidRuss's Avatar
RapidRuss
Gtex...LOL!!! it seems to me..That the price is weel worth to get rud of any head ache's?? I ran MSD..on another truck Years ago..with not a Problem..But..I had friends...
That called
me to pick them up in there trash??But... I like the 60,000 volts..It might be multy spark..But if it runs on a mild cammed 390 with one wire hook up!!! COOL!!!
Old Feb 14, 2004 | 03:19 PM
Ratsmoker's Avatar
Ratsmoker
I will need the compression ratio, and the head you want to run. I don't have any flow files on the 406 heads.
Old Feb 14, 2004 | 05:23 PM
Ratsmoker's Avatar
Ratsmoker
Here it is with 9:1 compression, edel heads and 941 cam.
Old Feb 14, 2004 | 05:27 PM
RapidRuss's Avatar
RapidRuss
Thanks Rat...I think then I might be able to put away my Neighbors DOG.... Hemi???
Old Feb 14, 2004 | 05:35 PM
RapidRuss's Avatar
RapidRuss
Rat...Did I read that right with the Edelbock head{I take they were the RPM} About 430 HP and 400 ft.lbs of torque?? Those Numbers sound good!!!
Old Feb 14, 2004 | 05:42 PM
Ratsmoker's Avatar
Ratsmoker
I can leave a HEMI ram wondering what the heck just happened and so can you. That was the RPM head. I think about 375HP would be closer to the real number. It says mine makes about 475HP and I know I'm not making that much.
That was 434 foot pounds and exactly 400HP. You got the two mixed up.
Old Feb 14, 2004 | 05:51 PM
RapidRuss's Avatar
RapidRuss
Thanks Rat!!! I really do thank you and FTE for it!! I be intouch as the program goes on!!!! Have a one!!! Russ!!!
