1978 - 1996 Big Bronco
Switching Odometer Units
Old Feb 13, 2004 | 04:33 PM
holleyman's Avatar
holleyman
I have a 1996 Full size Bronco that I brought up from the States to Canada. It has a digital odometer that reads in miles, I am wondering if the units of the odometer can be switched to Kilometers or do I have to purchase a metric cluster?
I have found articles on adjusting the constant for tire size but nothing on swapping the units from imperial to metric.
Old Feb 13, 2004 | 06:18 PM
BillyBob69's Avatar
BillyBob69
Unless I am mistaken, there is an option for switching from standard to metric and back. Unless they didnt do that til later...but I could swear that it was standard on almost all vehicals with digital odometers.
Old Feb 13, 2004 | 11:39 PM
bigric's Avatar
bigric
I checked it out in the service DVD--only the conversion constant can be changed. It states that if the display mode is incorrect, then the PSOM must be replaced. Bummer.
Old Feb 14, 2004 | 01:37 AM
holleyman's Avatar
holleyman
Thanks, bigric. I figured, I had the code reader on the unit, and I checked the manual I have here but no info. I guess I'll order a cluster.
Old Feb 14, 2004 | 04:01 PM
bigric's Avatar
bigric
Junkyard a cluster. I got a cluster in a yard for under $100; they're much more than that from Ford.
On an interesting note, while I was reading up on changing the units, Ford gives a 10-15% tolerance on the accuracy of the speedo. That's a lot IMO.
