Sponsored by: Innova
2002 F-250 SD CC subs help!?
Old Feb 13, 2004 | 02:59 PM
jasontrucks76's Avatar
jasontrucks76
I am a newbie to this site but I like it so far! My question is I have a 2002 F-250 SD crew cab and I am looking to put in subs in the back behind the seat and the only thing that I can come up with is the MTX box that is for the F-150 ext cab. This box holds 2 8" subs and sound ok but its not quite the low end I was looking for. I have had 10s in many ext cabs and liked the sound any ideas?
Thanks
Jasontrucks
Old Feb 13, 2004 | 05:00 PM
brianas's Avatar
brianas
if you like the low end bass--you generally need a larger
driver to produce those frequencies--at anaudible level
12" woofers are likely ur best best
15"woofers if you want some real deep grunt
10" woofers in a prolperly tuned setup will sound OK
I have not done any crew cab installs yet--so I cant direct
to the best enclosure or location etc...
But I would consider checking out a custom built sub enclosure
you will likely be happier with the end product
Decide how much boom you want--then go from there
g/l
Old Feb 15, 2004 | 01:11 AM
GN1's Avatar
GN1
I've got the same truck you do and bought a stealth box from Crutchfield that fits 1 10 and fits very neatly behind the front console. It kinda looks like a console in the back, including the cup holders. This box looks and fits perfect and as far as I know is the only box made to fit w/o a custom job. Threw the amp under the passenger seat.
Old Feb 15, 2004 | 01:19 AM
mcCrank's Avatar
mcCrank
I would look on crutchfield and get two high powered 10's. check the required box volume that each sub needs and go with the sub that requires the least amount of space. i would recommend building the boxes yourself over getting a prefabbed one. Its not hard at all and you can get the supplies from any home depot/lowes or whatever.
Josh
Old Feb 16, 2004 | 02:31 PM
jasontrucks76
Thanks for the imput guys! I am looking for something to drop in without any Mods. I dont keep the trucks too long and I haul 3 kids around in the CC so Im not shure the console will work but thank you for the suggestions!
Old Feb 17, 2004 | 06:12 PM
V-104Me's Avatar
V-104Me
I have a 10" sub behind my rear seat next to the package tray. The box is an off the self truck box, .75 ft. Thinking of adding another 10".
Old Feb 18, 2004 | 08:52 AM
jasontrucks76
Thanks V-104me.
Do you know the brand of the box? Or where you got it? I have a couple of local shops as well as a Best buy and Rex. I have removed the storage tray and tried a couple of diff. boxes but the seat back will not go up rite with the ones Ive tried You have given me some hope THANKS!!
Jasontrucks76
2002 F-250 CC SD V-10 3.73
Alpine head, Changer, Rockford 600a4, Rockfords in the doors and unhappy MTX 8s in the back.
Old Feb 18, 2004 | 09:52 AM
V-104Me's Avatar
V-104Me
jasontrucks76, here's who did my install:
Speaker Works, WWW.usdaudio.com Ask for Eric
These guys have a show room full of trophies for systems & installs. VERY Professional!!
BTW:the owners CC ROCKS!
Old Feb 18, 2004 | 04:26 PM
jasontrucks76
Ya I bet it does I checked out the link and that is top notch *****! That box would look good in my truck!! But 1995.00 is a little bit much. maybe before the wife and kids but not for now! This is the stuff Im into also and Im going to check on that gauge this week! Ill let you know what I come up with!
Thanks
Old Mar 3, 2004 | 10:54 AM
InstrumentTech's Avatar
InstrumentTech
Hey,
I got a '03 CC, and I put 2 10's in a custom box that I made. Cost me about 30$ and took me about 4 hours to make. The sound is just right, I'll never break anybody's windows but it is pretty loud. And the sound quality is amazing! It's like night and day pictures
Old Mar 3, 2004 | 11:58 AM
jasontrucks76
Thats Nice!!! Did you put a divider in the middle of the box or are bolth subs using the same air space? I think Im going to start building one this week end! I have been looking at the space and now I know it can be done Also would you mind sharing a little more info with me? Like What you are running for an amp and the dimensions of the box. also I couldnt tell from the pics but did you have to cut the molded plastic behind the box so it would fit? I am running bolth door speakers and the rear speakers on a four chanel amp I have the 5x9s on one chanel and the two subs bridged on the other. The amp is a Rockfor 600a4 and puts out aroud 700wats. this seems to work nice.
Thanks
Jasontrucks76
Old Mar 3, 2004 | 02:28 PM
InstrumentTech
Hey Jason,
1. no, I didn't put a divider in the box, so its the same air space. When I asked if I should I got mixed answers, mainly they said that it helps for support.
2. the dimensions are on my pics if you can zoom in enough, but basically it's a wedge 9" on the bottom, 3" on top, 17" tall and 36" long. Made it out 5/8" MDF and internal volume came out to a hair over 1.5 cu. ft.
3. I did have to cut that molded piece a little bit to make the box fit.
4. I'm running 2 Jl audio 10" with 4 ohm coils in parallel for a 2 ohm load with an Alpine amp that puts out 350w. And four Infinity 5X7's on another Alpine putting out 500w...they sound soooo sweeet!!
If I had to make the box again, I would shorten the 9" dimension to 8" 'cause my seat barely locks back
Old Mar 3, 2004 | 06:30 PM
Boots612's Avatar
Boots612
InstrumentTech,
I just bought a 04 CC F250
I'm guessing that the interior is the exact same on these years?
Also what JL's are you running the 10W6 or the 10W3'S
And where are you located? I would like to have you build me a box
Old Mar 4, 2004 | 08:26 AM
InstrumentTech
the '03 and the '04 are the same. Believe it or not I only have 10w0's, I thought about going to W3's later but I just can see it, I already have my amp. turned down a lot and it still rocks!!.
BTW, I'm over here way down in Texas...near Houston.
Congrats on your new truck!!
Old Mar 8, 2004 | 08:18 AM
jasontrucks76
Instrument and v-104me I built the box on sat and installed 2 W/O JL audio 10" and man do they rock I have always run the rockford sub but Im sold on JL I used your blue print off your pics instrument and took your advise on the 9" demension but I took it to 8 1/2 inces and in hind site Im glad because with the subs mounted 3" from the bottom their was just enough room to the back of the box. I did cut out the plastic molding around the box and added speaker grills and it fits perfect Thank you guys for your imput this site rocks!! and so does my truck now!!!
Take care
and Instrument Tech the check is in the mail for the blue print
Jason Trucks
