Sponsored by: Real Truck
trading up
Old Mar 12, 2002 | 08:44 PM
floor it's Avatar
floor it
trading up
considering trading my 99 f-150 for a s.d. either a v-10 or a 5.4. truck will be a used 99 or 00. are there any common problems with these trucks? I got my f-150 6 mo. ago and now it has developed a crack in the door.I found out after I got the truck that it is a common problem. ford refuses to fix.So i am trying to keep from making the same mistake twice.also truck will be a ext.cab 4x4.any advice would be greatly appreciated.
Old Mar 12, 2002 | 08:52 PM
TXTrailerdaddy's Avatar
TXTrailerdaddy
trading up
Go with the V-10 it's a lot more fun and brand new is only a $510 option. Gas mileage is close to the same so my vote is for the V-10
Ed
Old Mar 12, 2002 | 09:11 PM
Monsta's Avatar
Monsta
Sit. Stay.
trading up
I don't own a EC Super Duty but can comment on a few things that I have heard of.
If you choose the V10 (wise choice) get the '00. Mo' Powa!
EC doors squeak.
Front springs squeak.
Front sway bar bushings & links make noises when cold.
And a bunch of little things that may not consistute a vehicle wide problem but simply that it is made by fellow humans.
Those who DO own hopefully will add more. Good luck and have fun with your search!
Actually, I'm not suggesting that anyone add more problems, only the good stuff!! It outweighs all the other stuff. Unless you bought your truck where CEEJR bought his...
Old Mar 12, 2002 | 09:19 PM
TXTrailerdaddy
trading up
I got the optional squeek silencer with my SC. It's a little **** located in the center of the dash. When you notice squeeks you turn the **** clockwise and insert your favorite CD and then the only squeeking you hear is from the air guitar and dashboard drums.
Ed
Old Mar 12, 2002 | 09:38 PM
FortyFords's Avatar
FortyFords
trading up
Watch out for the 99' 5.4's piston slap,oil leak in head gasket area
on right hand side.
A few others, but overall great truck!
Rich
Ford Trucks Built Tough!
not with rocks
Watch out "X" Mayor of Truckville
Old Mar 12, 2002 | 10:27 PM
Outpost22's Avatar
Outpost22
trading up
Man, everyone says the SC doors squeak. I must have just got lucky with mine (knock on wood).
Don't forget to tell him about the "flutter".(Shhhhhh)
Old Mar 12, 2002 | 10:28 PM
NoMo's Avatar
NoMo
trading up
