Sponsored by: Real Truck
First Post
Old Feb 13, 2004 | 07:51 AM
ross_nc's Avatar
ross_nc
First Post
First post---Thanks to this site I have learned from your posts. While SDs are new to me, I currently have a couple of Ford vehicles.
A local dealer has a SD very similar to my wants/needs. 2004 F250 XL SC 6.0L w/auto trans (w/99P, 44B, T43, XC1, 17F, 52N, 572, 86T). It will take care of my needs (pull travel trailer w/tow capacity to spare in case there is a need for something larger. Don't need bells&whistles). I would appreciate any opinions about this vehicle. It may be possible that this truck has an 03 engine. Having read some of the past posts in this forum, a question is if this has a 03 Engine and not an 04 would that be a cause for concern? VIN = 1FTNX20P14EA9????
Thanks
Ross
Old Feb 13, 2004 | 08:21 AM
1956MarkII's Avatar
1956MarkII
Did you blank out the last few digits of the VIN? Without them, I can't do any research for you on the vehicle. The data plate (inside the driver's door jamb) will give you the month and year the truck was built.
Old Feb 13, 2004 | 08:33 AM
ross_nc's Avatar
ross_nc
Yes--A94117
Old Feb 13, 2004 | 08:48 AM
1956MarkII's Avatar
1956MarkII
The truck was built 9/26/03. Perhaps someone here can tell you for sure if this is a "good" build date; I believe anything built after April of '03 is OK, but the folks over at the diesel forums could tell you for sure.
A couple other interesting notes on this truck- check your e-mail.
Old Feb 13, 2004 | 09:03 AM
wbarber_07458's Avatar
wbarber_07458
With that build date the engine is probably an '03 engine.
There were several improvements made on the '04 engine so I would really not want to get a truck that had an '03.
There are several threads that detail the differences between and '03 and an '04 engine - it is worth getting the '04.
Just my $0.02.
Bill
Old Feb 13, 2004 | 09:04 AM
ross_nc's Avatar
ross_nc
Thanks, appreciate your reply.
Ross
