Superchips introduces the much anticipated Microtuner for 2003-2004 Ford 6.0L Powerstrokes!
Superchips performance programming in an easy to install hand held tuner!
Features include three powersettings: Tow Safe, Tow Performance, and High Performance.
Select which program you would like to use, then select any available user options. Program the vehicle with "Superchips Signature Tuning" in just a few minutes.
There's no need for tools, no need to access the ECU. Tuning the vehicle is simple and straight forward. The Ford Micro Tuner by Superchips Inc. is of a true plug and play design.
Available to ship May 15, 2004
PRE-ORDER NOW! Superchips will be raising their prices March 1st. Pre-order your unit now for the lower price. (Your card will not be charged until the unit actually ships.)
Just a question. Will any chip or programer be able to give us back pilot injection? If they could, then I'll lay the money down as I'm sure alot of others would too!
Does this unit store the original flash program so that you can restore the settings to the most recent factory flash if you need to take it in for service?
I assume it will, all other Microtuners do. All the information I have is in the announcement. I can't answer any questions other than point to the announcement. As I get more information I'll post it.
It has been my experience that Superchips products are of the very highest quality with the fewest bugs first time out. Since tuners are easy to change, I'll probably get one of these too!
Yes, the superchips unit can be returned to stock, just like the 7.3L unit
It will not leave trace codes, other than "more driving time needed", which of course is set everytime you disconnect your battery, let alone blink.
This code is never a cause for concern and goes away quickly.
There is no "stamp" left of the stock program to leave traces.
=o)
hmmm.....
It's pretty important that my e-mail address isn't posted....
You can have it, but I don't want it floating around here because I'll get 1,000 e-mails. I can send you e-mail if you have an address I can send to?
I saw on a site that it is only availble for the 2004 6.0 powerstrokes is this true or can it be used witha 2003 with the current flash updates????? Any one else heard this besides me?
That is what they said about the Predator, wanted the latest flash, that is. My predator works FINE on the June 03 flash. The programmers just don't know exactly what they are building on without this limitation.
