Sponsored by: Real Truck
Really dumb SD question.
Old Mar 11, 2002 | 12:17 AM
weldman's Avatar
weldman
Post Really dumb SD question.
[updated:LAST EDITED ON 11-Mar-02 AT 01:19 AM (EST)]My dad and I are expecting the new SD in a week or so, yeah! Can't wait to start getting it set up with tires, flares, bug deflector and towing acc!
MY QUESTION:
Now realize that I am coming from driving a simple '78 here!
Can you "roll-start" or "pull-start" these new manual-trannied diesel or fuel-injected engines? Ya know, if your battery goes dead, but you happen to be parked on a hill, so you put it in 2nd and the key to the run position, then pop the clutch to fire it up when you get rolling?
Clueless!
Matt
Old Mar 11, 2002 | 04:28 PM
weldman's Avatar
weldman
Someone must know!
Old Mar 11, 2002 | 06:44 PM
superdutymjh's Avatar
superdutymjh
If the battery is completely dead there won't be any power to run the electronics, so I don't think so. But if the battery is not dead and you have a manual tranny then you probably could. I'f your that worried about it then get a battery booster pack to carry with you.
P.S just turn off your head lights it's easier.
Peace,
Superdutymjh
Old Mar 11, 2002 | 07:38 PM
lugnut's Avatar
lugnut
Yes, it will work, on a gas engine anyways. Did it once on my 2001 V-10 just to see, and a couple of times on my 88 efi 460 'cause I had to. The other poster is probably correct in that you need a little power left to run the fuel pump and electronics, but I suspect that is also true of the pre-electronic engines. The alternator needs excitation voltage to produce power.
mike
Old Mar 11, 2002 | 08:45 PM
weldman's Avatar
weldman
So it'll work on a gas eh? What about the diesel superdutymjh?
Old Mar 11, 2002 | 09:14 PM
Neil's Avatar
Neil
It takes a minimum of 8 volts or 9 volts to make the injectors work on a Power Stroke, I don't recall exactly, but you do need somewhere around one of those numbers. If you need to know more info, I can get it for you, or refer you to the guy that has the scoop.
LW555's Avatar
LW555
That's actually a GOOD question. I would like to know too. Some people say you can, some say you can't. If your battery is dead, then you have no glow plugs, so I imagine it would be difficult especially if cold.
Old Mar 11, 2002 | 09:57 PM
weldman's Avatar
weldman
Thanks Neil and others! I guess I've gotten my answer, that it will work, thanks!
Old Mar 12, 2002 | 08:48 AM
NoMo's Avatar
NoMo
So what is the answer on the PSD?
Posts here seem to indicate a resounding "maybe".
Old Mar 12, 2002 | 09:53 AM
weldman's Avatar
weldman
If you could neil, confirm this for us for the PSD.
Old Mar 12, 2002 | 06:33 PM
N700MS's Avatar
N700MS
Old Mar 12, 2002 | 08:39 PM
Neil's Avatar
Neil
weldman, I will get more info for you shortly.
Old Mar 12, 2002 | 10:41 PM
Neil's Avatar
Neil
Here is the "offical" answer from Dieselmann regarding push starting a PSD with low or dead batteries. Hope this helps.
"You have to have at least 9 volts for the PCM to even power up. If the batteries are not completely dead you may have enough voltage to power the system providing you don't try to engage the starter."
Charles Ledger
ASE Master--Auto
Ford Chassis Master--Electrical, Climate Control,
Brake Systems, Steering & Suspension
For PowerStroke problems see dieselmann's Page at:
www.intellidog.com/dieselmann/
For Diesel Products and Supplies:
www.intellidog.com/dieselmann/catalog.htm
For AMSOIL Synthetic Lubricants:
www.intellidog.com/DieselSyn
Old Mar 12, 2002 | 10:51 PM
weldman's Avatar
weldman
thanks neil!! thats what I wanted to hear, you never know when you might need to do that!
Is it going to require a much bigger hill to start a 17.5:1 diesel than a 8.0:1 gas?
Old Mar 14, 2002 | 12:44 AM
Godzilla250v10's Avatar
Godzilla250v10
I have a 2001 250 with the V10....i don't think you have to worry about the battery dying....i have left my stereo system and lights for close to three hours and start the truck right up...
