body filler, please help!
Old Feb 13, 2004 | 12:07 AM
o0haco0o's Avatar
o0haco0o
ok on my 74 i have holes in the body, i don't know what they are from but they arn't rust holes i need to know if body filler (bondo) will fill these holes? some of the holes are quite large like dime to nickle size.
also im not quite sure how to use body filler. ive played around with it but any tips would help me out a bundle!
thanks in advance!
Old Feb 13, 2004 | 06:42 AM
Lobuck76's Avatar
Lobuck76
Bondo usually doesn't work well to fill holes, It's likely to fall out after you sand off excess.
Old Feb 13, 2004 | 08:10 AM
bob-63-292's Avatar
bob-63-292
You need to tack weld something behind the holes to support the filler. Truly retentive people try to weld and grind so that they need no filler. When they say "it is the best way", they are usually right, but, at some point you have to emerge from your garage and remind your family of your better qualities. Your call!
If you're welding, and cannot access the back, try cutting an oval shape that you can barely fit through the hole(s) and weld this into place before filling. Tacking a small stud on the plate before you put it in the hole can save a bunch of trouble. been there learned that.
Panel adhesive would work as well (search the forum), but make sure not to use it for load bearing components. Note that there are some newer motorcycles (i.e. MuZ) being manufactured where the entire frame is glued together with adhesives. But, the load on a motorcycle frame is less than the load on a truck carting a half-cord of wood ))
Bob
rswhitmore
Oct 15, 2014 05:14 PM
Wr822
2004 - 2008 F150
Apr 30, 2013 07:48 PM
Duke78
Paint & Bodywork
Sep 7, 2008 10:35 PM
bhardy501
Paint & Bodywork
Jul 31, 2007 10:05 AM
imlowr2
Mar 25, 2006 01:51 PM
