No Problems
Old Feb 20, 2004 | 04:30 PM
  #31
tn mac's Avatar
tn mac
cdtruckn
you are exactly right when mine was leaking I wiped it off and didnt pull over the holidays no leak thought it was not going to be a problem then started pulling again and leak came back, rear seal replaced 5k ago still no leak, just to show the techs. ability when went to pick up truck it had a terrible noise and vibration at the floor board, went back, tech. put transfercase skid plate on upside down causing bad noise as it was right against the transfer case. and you wonder why the problems dont get solved.
Old Feb 20, 2004 | 06:41 PM
  #32
cdtruckn's Avatar
cdtruckn
Crazy Huh!!!!
Old Feb 20, 2004 | 09:32 PM
  #33
FLFordOwner's Avatar
FLFordOwner
I have 3800 miles on mine a month old, found out i cant run my heater at a truck stop, bank, street light, gas station, highway, anywhere, fumes from other cars and even my own fill the cab i have a 50k truck and a 2 dollar ac system i cant belive more people arent bitching about this
Ford wtf are you thinking ? you people cant be that stupid or you just dont give a horse pucky
Old Feb 21, 2004 | 01:50 PM
  #34
tn mac's Avatar
tn mac
FLFORDOWNER
you have a problem mine is ok to idle with engine on no fumes, there was some posts about cracked exhaust manifolds, and also some that were not put together correctly take it to dealer and complain.
Old Feb 21, 2004 | 02:46 PM
  #35
forrestgump's Avatar
forrestgump
January build 03, 4800 miles, except for bh leak no problems
Old Feb 22, 2004 | 07:34 AM
  #36
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
READ READ READ READ
Go to this thread, read completely…. Follow, on page 3..MLF250’s format, it is good…and easy! and post. Important update to instructions on page 6.
Most important part of this data...also, there “is” owners out there that have had no problems. To be fare to my methodology… I need the same from the “no problem” owners.. i.e. mileage (mileage is the odometer reading)
important a “no problem” statement if you have had none.
ODOMETER reading at time of problem is critical.
In addition, please read more instructions, bottom of first page, posted by Tim L
The simpler the writing (posting) of “problem/odometer” reading………….the easier it will be to collate.
Do not need many words, NO stories.
I must reduce all the date into a usable format; extra words will take more time to complete.
https://www.ford-trucks.com/forums/s...hreadid=185570
I implore all 6.0 owners to please take the time
Thanks
Tim
Old Feb 22, 2004 | 09:50 PM
  #37
Jmitch12's Avatar
Jmitch12
05/03 build date....Indy
13,500 miles
Had problems around 10000 with H20 in Fuel light. Have cleaned it out several times and not a prob since.
No flash of any kind
16-18mpg empty on Highway (75-85mph)
12-14mpg around town
No other problems to mention
Should I get any of the flashes????
Old Feb 23, 2004 | 07:47 AM
  #38
IB Tim's Avatar
IB Tim
13,500 miles
NO
Thought I should say it so there is no mistake about getting a flash
Old Mar 20, 2004 | 02:16 PM
  #39
Tower Jack's Avatar
Tower Jack
Originally posted by Tower Jack
Made it to 8000 np
10500 now and still going strong with a good blackstone report at 9600
BTW is there two treads for this now? Y not merge them
I seem to have lost my signiture. Anyone have any ideas on getting it back. In edit options I have show sigs checked and in edit profile my sigs show up.
Old Mar 20, 2004 | 02:37 PM
  #40
IB Tim's Avatar
IB Tim
No there never was supposed to be two threads ONLY one.
Old Mar 21, 2004 | 12:15 PM
  #41
Hunter40's Avatar
Hunter40
Still no problems. Got it yesterday. 31.6 miles.
Old Mar 21, 2004 | 01:24 PM
  #42
aurora_1's Avatar
aurora_1
Originally posted by cdtruckn
How many of you guys have looked under your trucks for the R/M oil seal leak?
The reason I ask is that I have not seen a 6.0 that didn't leak at the rear main seal.
CDTruckN:
I have a June 03 build and while there was that "hanging drip" on the bell housing that I noticed after running about 500 miles, I wiped it off and have been checking ever since. That was back in July and now I have 21000 miles on the truck without ANY LEAKS. The BH has been absolutely dry as a bone ever since. Not even dirt is accumilating in the area (which is an easy way to spot a very small leak). So in my case I do believe it was excess lube as the engine does not leak one drop and that "hanging drip" was the only one ever seen.
Old Mar 21, 2004 | 01:26 PM
  #43
IB Tim's Avatar
IB Tim
Fellow New Mexican that is good to read.
Old Mar 24, 2004 | 10:24 AM
  #44
pacemaker's Avatar
pacemaker
F-250, 2004, CC, 6.0, auto. No problems whatsoever, 4300 miles and counting. 14-16 MPG around town. Truck build is 11/03, not sure on the engine build date. the white tags have 4907? Blue tag says 2004.
Old Mar 24, 2004 | 10:57 PM
  #45
senor's Avatar
senor
2004 w/ 8900 miles and no problems. I'm very satisified with the overall quality and performance of this truck. Lots of power and really like the transmission for towing.
