weather situations for priming...
Old Feb 12, 2004 | 11:01 PM
o0haco0o's Avatar
o0haco0o
Lightbulb weather situations for priming...
is there a certain temperature it has to be outside to prime my trucks interior? it pretty damn cold here and i dont want to mess it up because its my third time to do it.
Old Feb 13, 2004 | 01:55 AM
stangboy_82's Avatar
stangboy_82
check the can it will say you have different temp ratings on the thinner so that it will spray right plus the colder it is the longer it's gonna take for it to dry. and stuff like that but basically check the can or check with the manufacturer of the primer you are using cause that's the best way to find out the temperatures and everything else you need to know for spraying it.
Old Feb 13, 2004 | 09:45 PM
fordpilot2's Avatar
fordpilot2
Most paints swwm to best around 70 degrees.
Warm your interior with a heater and warm
your paint somehow.
Good Luck!
