carb woes
Old Feb 12, 2004 | 08:36 PM
Grass Valley Cal's Avatar
Grass Valley Cal
Unhappy carb woes
I have found that if i spray carb cleaner around the back of carb when running it will kill the motor around back i mean behind the carb between the firewall and carb body I have tried to track down the leak but cant find where the problem is ????? also how do you tell if your dist parts are worn or failing ??? thanks Frank 1986 f150 4x4
Old Feb 12, 2004 | 08:59 PM
brown 4x4's Avatar
brown 4x4
Make sure your carb isn't loose causing a vacuum leak underneath. Mine has a tendancy to do this over time.
