1978 - 1996 Big Bronco
Heater Motor
Old Feb 12, 2004 | 06:48 PM
Outlawwv's Avatar
Outlawwv
Heater Motor
my heater blower motor starting squelling- that lasted for about three days and now it only works on high speed any ideas ??
Old Feb 12, 2004 | 07:33 PM
Corey872's Avatar
Corey872
Bad bearings? Along with the bad bearings probably comes enough friction to keep the motor from turning at the lower power settings. New motor shouldn't be more than $15-20.
Old Feb 12, 2004 | 08:23 PM
Steve_Uzi's Avatar
Steve_Uzi
If it only works at High speed then your blower motor resistor is shot...If you look under the hood, there should be a wire that connects to the motor and then a wire that connects to a 3 prong blower motor resistor on your HVAC housing under the hood. I would get a replacement from a Junkyard as I don't think you can get that new, well maybe from Ford.
Sounds like you will need a new Blower motor too... I replaced mine recently and it was $22.
Old Feb 12, 2004 | 10:19 PM
JBronco's Avatar
JBronco
The squeaking sounds like a bad bearing on the motor. Maybe it got hot and then burned up the resistor? I think that you need both parts.
Old Feb 12, 2004 | 11:53 PM
BillyBob69's Avatar
BillyBob69
Here is a site that can help.
http://www.autozone.com/servlet/UiBr...3d800a39e2.jsp
Old Feb 13, 2004 | 06:40 PM
Outlawwv's Avatar
Outlawwv
thanks guys i'll check it out this weekend a let you know what it was
