Sponsored by: Auxito
lifting an 02 2wd
Old Feb 12, 2004 | 04:06 PM
jtsharkin9's Avatar
jtsharkin9
lifting an 02 2wd
hey i'm new to the forum and ford trucks and would like to lift my 2002 2wd f-150. i was wondering what was the best way and what kit to use. i would like to go up around 4-6 inches. thanks..
Old Feb 12, 2004 | 07:13 PM
BVFD1983's Avatar
BVFD1983
Why??? Form with no function sucks.
Old Feb 12, 2004 | 07:34 PM
jtsharkin9's Avatar
jtsharkin9
what do you mean why, i want to lift it a bit just for the simple fact it looks good
Old Feb 13, 2004 | 12:21 AM
Racerguy's Avatar
Racerguy
Hi jtsharkin9 and welcome to FTE
I wonder if a body lift would do what you want if you cant find a good suspension lift.
You might not get as much lift as you want but it might be ok.
Old Feb 13, 2004 | 04:13 AM
duff man's Avatar
duff man
6 inches is alot thats what i tell myself anyway.
i personally dont like body lifts. you sometimes have issues with wiring length and so on plus all u see is the frame under the raised body. i would go with a good suspension lift u can find them just about anywhere. look in offroad mags.
also remember when u put those big tires on you will want lower gears!
Old Feb 13, 2004 | 06:23 AM
jtsharkin9's Avatar
jtsharkin9
thanks for the suggestions guys, i guess i need to do a lil research on what the best kits aree for what i'm looking to do, again thanks for the help
Old Feb 13, 2004 | 09:10 AM
GoodJava's Avatar
GoodJava
Check out the Fabtech Lifts thread on this BBS. I'm leaning towards the Fabtech 3.5" spindle kit or the 3.5" performance suspension kit - local quotes are within $250 of each other - the performance lift comes with shocks.
I was trying to talk myself into going cheap (body lift) but lots of people have talked me out of it for a number of reasons. Primarily I don't want the risk of body/frame separation in a collision that the body lift can exaggerate. Also consider that your factory wheels might not have the appropriate back spacing for these kits which would force you into aftermarket wheels. Only bad if you're counting your pennies Two shops indicated that I would need different wheels and one said my stock wheels were fine as long as I ran the stock tires. Currently I've got Michelin LTX 265/75 R16s. I'm figuring I'll run with the current wheel/tire package and then upgrade/upsize in a year or two to 285/75 R16 BFG TA/KOs and rims.
