Sponsored by: Real Truck
need a new V10 engine
Old Feb 12, 2004 | 02:26 PM
F250reddog's Avatar
F250reddog
Unhappy need a new V10 engine
I had the tranny replaced a couple of weeks ago and yesterday all hell broke loose coming home from work. I assumed it was the tranny because it was just put in and the horrible noises sounded like they were coming from under me not in front. Had it towed to the local shop and found out this morning that it threw a rod
The shop wants $6100 parts and labor for a Ford rebuilt which includes a $1500 core charge. They say they can't use the block because the rod blew a 3 inch hole in the side. I didn't see it for my self. Is this likely? They say ford charges them $1500 because the block can't be used again. Is this true? 6K is a lot of money for me especially considering I just spent $3800 on a new tranny.
Any suggestions on what to do or where to find a good 6.8L with a warranty (Ford only offers 3yr 36K on theirs). Thanks.
Old Feb 12, 2004 | 04:45 PM
NoMo's Avatar
NoMo
Wow! This is the first catastrophic V10 failure I can ever remember reading about.
You should definitely shop around as various dealerships charge diffferent prices. You might also look at some of the local salvage yards to see if there might be an engine available. Probably wouldn't have much of a warranty, but it'd be significantly cheaper.
Old Feb 12, 2004 | 05:16 PM
jhemr's Avatar
jhemr
BRAND NEW FORD 6.8L V10 TRITON ENGINE
Saw this on ebay.....Item number: 2459916197
It's in or around Oklahoma City, OK
Buy It Now.....$3495
Old Feb 12, 2004 | 05:49 PM
99f350sd's Avatar
99f350sd
I'd be scarfin that baby.....
Old Feb 12, 2004 | 06:00 PM
F250reddog's Avatar
F250reddog
Thanks for the replies.
I did actually see the V10 on Ebay. It seems too good to be true. I E-mailed the seller about the warranty and he said 30 day! I fired back asking if it wasn't backed by Ford (being a new engine and all). He said no. That makes me nervous. What do you guys think?
Also, if I were to find a newer year (mine is '99) could I use it? I would like to get something newer and get the 310hp instead of 275hp on 1999's and hopefully avoid the flying spark plug problem. Would this require a new computer or other such stuff?
Old Feb 12, 2004 | 06:12 PM
HeavyAssault's Avatar
HeavyAssault
Yes a different computer is required.
