Reset computer
Old Feb 12, 2004 | 01:15 PM
kaih's Avatar
kaih
Reset computer
What are people's thoughts on resetting the computer after installing a bolt on. I put a Gibson cat back on last week and did not reset the computer.
Resetting the computer makes the computer know about the part immediately. But if you don't reset the computer, it gradually adjusts over time or is this wrong.
Old Feb 12, 2004 | 02:53 PM
buzzard's Avatar
buzzard
I don't think you really need to worry with your exhaust install. When you disconnect the battery, reconnect and then start up, the system will want to re-learn what's going on with monitored systems, but the exhaust, after the downstream O2 sensors, isn't monitored.
Old Feb 12, 2004 | 09:20 PM
swann79's Avatar
swann79
Why not reset it just to make sure? It really doesn't take that long to re-learn anyway.
I've made it a habit to reset mine after every oil change. I decided to do this because the whole truck started flipping out on me one day, shortly after I bought it. The 4WD wouldn't engage, the air suspension wasn't working, and it was running like crap. After tinkering all day and pulling all of my hair out, I finally had the idea to reset the computer. Problem solved!
Old Feb 14, 2004 | 08:04 AM
Voksboy's Avatar
Voksboy
So how do you reset the computer? Just unplug the batt and thats it? How long?
Thanks
Old Feb 14, 2004 | 08:06 AM
the4by4freek's Avatar
the4by4freek
disconnect the negative battery terminal for 20 min. Thats it!
Old Feb 15, 2004 | 07:39 AM
Voksboy's Avatar
Voksboy
Brillant thanks
62FE4x4
Apr 8, 2017 03:50 PM
Johnblagg
Oct 18, 2010 08:14 PM
gthbryce
May 26, 2009 03:54 PM
djking
Computer Chips & Tuners
May 9, 2008 06:00 PM
livinezy
1983 - 2012 Ranger & B-Series
Feb 6, 2008 11:00 AM
