Axle gears ???
Old Feb 12, 2004 | 02:15 AM
nicebenz68's Avatar
nicebenz68
Axle gears ???
Hello, I just purchased a 1993 F250 S/C Diesel with Automatic. The axle number on the sticker on the door jam is "35". Can anyone tell me what ratio this axle is?
Thanks,
Andy at Fort Hood
Old Feb 12, 2004 | 09:18 AM
Frankenscagmachines's Avatar
Frankenscagmachines
Looks like 4.10 without limited slip. Here's the decoder article:
https://www.ford-trucks.com/articles/axlechart.php
Old Feb 12, 2004 | 10:12 AM
nicebenz68's Avatar
nicebenz68
Thanks, Sure does not act like a 4:10 rear end. Engine turns 2000 RPM's at 65MPH. My 88 turned well over 2600 at 65. The only difference being the 4 speed tranny (93) instead of a 3 speed (88).
Thanks again, Andy at Fort Hood, Texas
Old Feb 12, 2004 | 03:33 PM
ExcellentRed's Avatar
ExcellentRed
but what size tires do you have? I have 31's an a 4.10 and in OD (.7 ratio) I run 2300 I think. I do know I run 2000 at 55
Old Feb 12, 2004 | 09:53 PM
nicebenz68's Avatar
nicebenz68
Both trucks ran 235-85R16's.
Old Feb 12, 2004 | 10:40 PM
fordmarshall111's Avatar
fordmarshall111
in my f-250 with 4.10s i run 2300 at 65 in OD, in 4th gear (1:1) its turning 3000 RPMs. tires are stock 235/85/R16, so basically 31's.
Old Feb 12, 2004 | 11:50 PM
nicebenz68's Avatar
nicebenz68
My 93 F250 runs right on 2000 RPM's at 65 MPH in OD. The tag on the door piller says 35 which according to the listing shown at the link above says the gears are 4:10. Sure does not seem correct with the large difference between yours and mine. I do not know what to think. I have looked at the tag on the differential but it does not state the ration as most Ford diffs do.
Thanks for all of your help.
Old Feb 13, 2004 | 12:35 AM
SoCalDesertRider's Avatar
SoCalDesertRider
Maybe somebody changed the gears?
Old Feb 13, 2004 | 11:51 AM
moose94's Avatar
moose94
do f250's have a 9" rear end or is it a 10.25?
Old Feb 13, 2004 | 02:51 PM
wtroger's Avatar
wtroger
do f250's have a 9" rear end or is it a 10.25. Some have 8.8 some 10.25 depends on the gvw of the truck.
