Sponsored by: Kumho
mounting bilsteins?
Old Feb 11, 2004 | 07:27 PM
BigDawg54's Avatar
BigDawg54
Question mounting bilsteins?
just bought 4 new Bilsteins for only $208 for my SD. i remember someone saying that bilsteins are supposed to be installed oposit that of the stock ones. inverted i guess you would say. is this true?
Old Feb 11, 2004 | 07:34 PM
DCSpecial's Avatar
DCSpecial
Bilsteins mount body up, boot down.
Hope this helps.
Old Feb 11, 2004 | 07:36 PM
BigDawg54's Avatar
BigDawg54
thanks buddy
Old Feb 12, 2004 | 06:08 PM
BigDawg54's Avatar
BigDawg54
one more Q, why are they invertedly mounted and not like the stock with body at bottom?
Old Feb 12, 2004 | 06:59 PM
DCSpecial's Avatar
DCSpecial
I believe it's an issue of longevity. If it were boot up/body down, water, dirt, grime, etc... can sit on the shelf that the shock body creates and prematurely wear out the seal around the piston. With it boot down/body up water, dirt, grime, etc.. can't really sit around the seal like that and cause it to fail.
Hope this helps.
