lifter noise
Old Feb 11, 2004 | 06:28 PM
57_ford's Avatar
57_ford
lifter noise
Hi, I have a 77 F150 4X4 with a 302. When it cold when I first start it some of the lifters tap. After a mile or so up the road it goes away. I am sure it is not a rod knock or a piston slap and the truck runs good other wise and has 65 lbs of oil pressure. It just has the sound of lifters that hasnt pumped up with oil yet. Is it common for these engines for the lifters to bleed down over time? Or am I off base with this? Thanks for any help.
Old Feb 11, 2004 | 08:03 PM
daerhldgs2's Avatar
daerhldgs2
rods have a double knock lifters don't , sounds like a wrist pin or piston slap , they make noise when cold and go away as the engine warms up .
