1978 - 1996 Big Bronco
IAC install
Old Feb 11, 2004 | 04:53 PM
broncobillybob's Avatar
broncobillybob
IAC install
hey guys,
thanks to info from this forum I have found the root of my idle problem to be the IAC. It should arrive no later than this friday, so what can be expected form this install? Looks like I just remove the two bolts and disconnect the sensor to take out the old one. Is there anything extra I should be aware about, i.e. weird engine stuff, battery, etc. The IAC is on the left side of the throttle body.
-wb
___________________________
1993 Bronco XLT 351W 5.8L
Flowmaster
KN FIPK
Old Feb 11, 2004 | 10:13 PM
BOJOFASO's Avatar
BOJOFASO
sounds like you got the install pinned. just be sure to replace the gasket and clean the mating surfaces well.
Old Feb 11, 2004 | 11:06 PM
broncobillybob
Gasket? will that come w/ the part? here's hoping. -wb
__________________________--
93 Bronco XLT
Old Feb 12, 2004 | 07:21 AM
fcarruth's Avatar
fcarruth
The gasket should come with the part. What you may want to consider when you do this is to take the throttle body off and clean it real good with throttle body cleaner. Don't use carb or any other cleaner because it can take the coating off the TB. It made a big difference when I did it on mine. If you do take the TB off, it may be a good time for you to replace your throttle position sensor if you have a few extra $$. It costs about $30. from the Zone.
Good luck,
Old Feb 12, 2004 | 08:39 AM
broncobillybob
whew, thats a load off. i don't have a lot of extra dough to spend on unexpected parts. now i can concentrate on the task at hand: improving my Bronco instead of fixing broken stuff. this is the last broken thing on the list of crappy broken stuff. thanks guys. -wb
____________________________
93 Bronco XLT 351W
