brake lines
Old Feb 11, 2004 | 10:52 AM
johnp123's Avatar
johnp123
brake lines
Hi,
Can someone tell what the metal brake line diameter is and the thread size for the nuts on the brake lines.
Thanks.
Old Feb 11, 2004 | 12:17 PM
MudinMan19704x4's Avatar
MudinMan19704x4
i beleive it like 5/16 and the nut size is 3/8's but on some of the new wheel cyl's they put 10mm(bleeder valve) on there fer some reason.....
rebocardo's Avatar
rebocardo
Generally speaking, 3/16 line with 7/16 fittings are found on Ford trucks except at the master cyl. where the fittings are a difference size.
Old Feb 11, 2004 | 12:19 PM
rebocardo's Avatar
rebocardo
Yes, on the cyl. "Made in Italy" from Autozone.
Old Feb 11, 2004 | 12:21 PM
MudinMan19704x4
i just redid alot of lines and brake parts...The 3/16-5/16 I cant remeber but I am pretty sure the nuts arent 7/16.....I think I might go check In a little bit....and I bought some from a local store (they are made in USA)
Old Feb 12, 2004 | 03:53 PM
rebocardo's Avatar
rebocardo
The nuts are 7/16. I measured a spare line I had left over from my brake job.
