77f-350 worth it please help
Old Feb 18, 2004 | 04:18 AM
1976BeaterF150's Avatar
1976BeaterF150
well my 300/c4 has no problem doing 80 on the highway, i dont know the rear gears, but i will get around to getting the numbers for them, and that 80mph is with 1000lbs in the bed
Old Feb 18, 2004 | 06:00 AM
neverenough's Avatar
neverenough
Originally posted by Will in V.A
i can't seem to figure out the owners manual as far as tow rating go'es .. do you guys know any ways to calculate that ?
There is no rating for the 300-6. Generally you just go by the std rating. That would be 2000lbs. I think that is a little low, but I wouldn't recommend a combined load weight (on the bed, the trailer, and stuff on the trailer combined) of more than 3000 with the 300-6, as a daily driver. Adding a larger V-8 somewhere down the road would make the towing capacity skyrocket.
If everything is in good mechanical condition, with little rust/damage, I would say it is in the $1800-$2400 value range , with that motor.
pgood1
Dec 4, 2013 05:12 PM
BlueOvalBud
Aug 29, 2009 10:12 AM
68Rookie
Jun 23, 2009 12:45 AM
SgtDan
Aug 6, 2008 01:10 PM
horndwg
Jun 19, 2003 11:42 AM
