Hesitant starting
Old Feb 11, 2004 | 12:10 AM
phonebem's Avatar
phonebem
Hesitant starting
I copied this from the Superduty forum hoping maybe someone here would have some input. To the moderators, sorry for the double post, I'm trying to save you the trouble.
I have a '01 SD with a 5.4 whenever it gets cold, usually in the mid teens (before you guys in the tundra that we call Minnesota, Wisconson, New England, Canada, etc. say anything I know you consider that warm ) and sits overnight my truck will crank over like normal and attempt to fire like normal but shudders and spudders for a few seconds then dies. I'm wondering if the fuel pump doesn't kick-in fast enough allowing the engine to run out of fuel or is it something else. I don't get a check engine light, and my battery seems fine (just by the dash meter before turning the key). As I said it is only after sitting overnight when its cold. Always fires right up on the second try like everything's fine. Anyone have any ideas? Thanks.
Old Feb 12, 2004 | 08:55 AM
LxMan1's Avatar
LxMan1
Sticky IAC maybe?
Old Feb 18, 2004 | 02:04 AM
phonebem's Avatar
phonebem
OK, I don't know if this will help anyone, but we just had a warm spell for the last couple of days. Both mornings the truck fired right up on the first try.
Old Feb 18, 2004 | 11:33 AM
LxMan1's Avatar
LxMan1
I would inspect the IAC to see if it is gummed up a bit. It will react slower in colder temps.
Jimmy
04mudslinger
1997 - 2003 F150
Jan 17, 2015 03:34 PM
rssnape
Dec 30, 2014 05:17 PM
JUMBO_UTE
Dec 6, 2006 06:48 PM
tcbofade
Missouri Chapter
Oct 31, 2006 09:15 PM
je250ff
Aug 13, 2006 04:47 PM
