Hi,
As weather permits, I'm going to start getting my F-1 ready to paint. The body is pretty solid but I do have some surface rust to remove and a few spots that will need to be patched.
My question is about tools, or more precisely, what are the essential air / power tools needed to handle this type of prep? I have the welding covered but what is best for cutting out the rusted areas and some of the initial sanding of surface rust.
Thanks in advance for any advice. (I did a search before posting this question but didn't find enough information).
I am not sure exactly what you are going to do but a DA (double
acting) sander is often a weapon of choice. Be aware as always you get what you pay for. Look at control (rpm), ease of use (
does it feel right..can you feather edge) and noise.
They have sticky paper types and velcrow stick pads. I
have used both..both work good.
I like cut off wheels in either air or electric flavored tools. I've used them in my DeWalt 4 1/2" angle grinder and in an air dremel with a 1/4" arbor. Now that I think about it I have a cutoff wheel for my circular saw too! That's a little extreme tho.
The only thing I have against them is they don't last too long. I needed 2 to cut a little over 12 ft of .070 not long ago.
On the plus side they're real easy to cut a straight line with and nuthin' ever warps.
<cr>
I don't know what they are called but they are basicly a Scotch Brite pad that attaches to a die grinder. Great for getting into close quarters like sills and what have you.
for cutting out the rusted area's if it's just a coroded hole then you can use a drill and a #30 drill bit chain drill around it pull the corroded piece out with a pair of pliers then use a rotary file in the drill to clean the edge of the metal up and go about the rest of your repair
Just my opinion, but If I were in your position, I would definitely have plans of getting a sand blaster. They certainly have their place as far as I'm concerned. Good luck with your project.
