Sponsored by: Auxito
Beep In Dashboard
Old Feb 10, 2004 | 05:38 PM
jereece's Avatar
jereece
Beep In Dashboard
I have a 2000 F-150. I recently had to have the starter replaced by a local shop (was stranded). After picking up the truck and driving home everything worked fine until I turned the engine off and removed the key. When I removed the key, something in the dashboard beeps 5 short times. Does anyone have any idea what this could be?
I originally thought my CD / Radio needed to have the clock set, but upon setting it I still have the problem.
I can't determine for sure if it is coming from the CD unit or somewhere else in the dash. Any suggestions is appreciated.
Old Feb 10, 2004 | 08:58 PM
Racerguy's Avatar
Racerguy
Hi jereece and welcome to FTE
Does your airbag warning light come on and prove out after a few seconds when you first turn the truck on?
About the only thing I can think of that would make 5 short beeps is an airbag problem.
Does it beep every time you remove the key?
Maybe try removing a battery terminal for 10 minutes or so and see if clears whatever is causing the beep.
Sorry that I sound vague here. Maybe someone will come along that has ran into this problem before.
Old Feb 11, 2004 | 04:46 PM
jereece's Avatar
jereece
Yes the air bag system appears to be working properly. It does beep everytime I remove the key IF the ignition was turned on. If I simply insert the key and remove without turning on the ignition, then no beeps. I will try removing the battery cable for 10 minutes this weekend to see it that resets anything.
Thanks and great forum. I am amazed at the number of users!
Jim
Old Feb 11, 2004 | 10:18 PM
Racerguy's Avatar
Racerguy
Please let us know what you find.
