Tranny Temp sensor
Old Feb 10, 2004 | 03:42 PM
Jobless's Avatar
Jobless
Tranny Temp sensor
Is there a factory hole in the C6 tranny for installing a Temp Gauge?
I know that I can put it in line with the cooler hose or weld a fitting into the pan, but wanted something a little simpler if possible.
Thanks
Brad
Old Feb 11, 2004 | 03:27 PM
MontgomeryGeorgeWJr's Avatar
MontgomeryGeorgeWJr
If Im not mistaken (I couldbe cause Im going from memory here) - there is a pressure service port on the C6, Drivers Side, Jsut forward of the gear selector. Normally has a plug in it. It's ment to read the overall operating pressure inside the tranny (which can be up to 300 psi).
Ive got my temp sensor and a presure sensor in a T-block plumbed into the cooler line as it exits the tranny. Wokss well there also, but the pressure's not as high on mine (about 100 psi when the coverter is stalled, 30-70 rest of time depending on the load).
