Sponsored by: Real Truck
Daytime Running Lights
Old Feb 10, 2004 | 12:58 PM
SUPERD250's Avatar
SUPERD250
Angry Daytime Running Lights
I BOUGHT A 2000 F250 SUPERDUTY V 10 , I WAS WONDERING HOW U SHUTOFF THE DAYTIME RUNNING LIGHTS OR EVEN IF U CAN??
Old Feb 10, 2004 | 02:55 PM
Waxy's Avatar
Waxy
You can't turn them off, but there have been people here who have rewired them, I'm not sure of the specifics.
Try a search, you'll likely find the answer.
Waxy
P.S. All caps is taken as yelling.
Old Feb 10, 2004 | 06:35 PM
Brian_Puff's Avatar
Brian_Puff
there is a fuse under the hood that i pulled. i dont remember which one right off hand it was, but if you look in your owners manual it will tell you which on it is. just look at the page with the fuse box on it and look for the one that that says DRL or daytime running lights, i dont remember.
i'm sure there are alot of other ways to do it, but i just did this b/c its the easiest. (maybe 5 minutes from the time i opened the
the only reason i took it out was because coming onto an AirForce base at night the "cops" always try and give me a hard time about not turning off my head lights like their little sign says to do....
Old Feb 10, 2004 | 09:28 PM
SUPERD250's Avatar
SUPERD250
does it shut anything else off???
Old Feb 10, 2004 | 11:20 PM
Brian_Puff's Avatar
Brian_Puff
not that i've noticed. the headlights and everything still work normal. it just killed the DRLs
Old Feb 10, 2004 | 11:55 PM
Trav460's Avatar
Trav460
On my 97 if i pulled the fuse it knocked out the horn and flas to pass head lights.. i ended up disconnecting the module behind the bumper.. but this was back in 97.. your truck proboly has a sesor of some sort
Old Feb 11, 2004 | 07:33 AM
SUPERD250's Avatar
SUPERD250
ok thanx alot guys !!! we will see what happens!!
Old Feb 11, 2004 | 06:43 PM
spacegoast's Avatar
spacegoast
Remove the daytime 80% resistor circit jumper behind the left hand headlamp.this will allow the headlamps to power up only when the switch is turned on.
NOTE:Found this out wile installing daytime running lamps that my truck was not equipped with from the factory 2004 f350 SD after to many trips to the parts counter at ford.
I am on a first name basis with the parts manager although i dont know what name he calls me before i make it into the counter aria seen threw the glass partision.
Old Feb 11, 2004 | 08:45 PM
SUPERD250's Avatar
SUPERD250
but mine is a 200o will it have that sensor? and if so what switch r u talking about?? man i dislike those lights!!
Old Feb 11, 2004 | 11:38 PM
pepperoni's Avatar
pepperoni
This 'might' help;
https://www.ford-trucks.com/forums/s...%25252Bdaytime
Old Feb 12, 2004 | 10:43 AM
spacegoast's Avatar
spacegoast
the resistor is encased in a metal perforated cage with a white ceramic inner body attached to the raderator rear fraim behind the LH headlamp in my super duty.
Old Feb 12, 2004 | 03:00 PM
SUPERD250's Avatar
SUPERD250
i checked the resistor behind the headlamp and disconnected ahh what a beautiful thing no more daytime lights , thanks everyone !!
Old Feb 12, 2004 | 06:13 PM
islandblue's Avatar
islandblue
I have 2002 SD Crew 250 and it has no running lights???
Old Feb 12, 2004 | 06:38 PM
haroutd's Avatar
haroutd
From: I'm lost somewhere in NJ -- can someone please find me?!?!?!?
That's because yours is not a Canadian truck! Don't complain -- I hate DRL.
I helped a friend pick up a BMW recently. I was involved in every part of the purchase (knew the dealer, got him a discount, blah blah blah). Unfortunately, the dealership forgot to ask if he wanted the DRL on or off while we were there, so he called him later. My friend said "turn it on!" without consulting with me. I make fun of him and his "metrosexual" car constantly. "You only made one decision on this car, and made it gay by doing so." You get the picture.
Don't mean to offend anyone who likes DRL -- that's your right. Don't bother flaming me, I don't care.
Old Feb 13, 2004 | 10:24 AM
pepperoni's Avatar
pepperoni
Hahaha! Thanks for making my morning.
