Wait to start light
Old Feb 10, 2004 | 09:38 AM
bkrfrmhell's Avatar
bkrfrmhell
Wait to start light
How does the wait to start light work? Goes on when glowplugs are enagaged and goes off when they shutdown? Or is it temperature sensing? I find on mine it doesn't stay on very long when the engine is warm, maybe 2 seconds maybe 4 or 5 seconds when it is cold.
Old Feb 10, 2004 | 11:36 AM
wlihntr's Avatar
wlihntr
you got it,the wait to start light goes off when the computer sences there is enough heat in the cubustion chamber to light off the air/fuel charge. on some starts(mostly with a cold engine) the glow plugs will stay on for a few minutes(after the light goes off) while the engine is running
Old Feb 10, 2004 | 12:24 PM
bhs2869's Avatar
bhs2869
If I understand right the glow plugs stay on for about 2 minutes on each start.
Old Feb 10, 2004 | 04:32 PM
OARLOX's Avatar
OARLOX
In the event thay you had a single or multiple glow plugs that were faulty or a faulty Relay. Would this "Wait to start" indicator act any differently?
Old Feb 10, 2004 | 04:34 PM
shendoa's Avatar
shendoa
no
Old Feb 10, 2004 | 05:44 PM
JMorton's Avatar
JMorton
The glow plugs cycle for 120 seconds, the light will stay on longer when cold, shorter when warm. Sometimes if the relay is faulty the light won't come on or will come on and go off real quick.
Old Feb 10, 2004 | 06:12 PM
petes4x4's Avatar
petes4x4
I've had my relay not working and the light going on like the relay was working
Old Feb 10, 2004 | 07:28 PM
JC 6.0's Avatar
JC 6.0
The glow plugs cycle time depends on the EOT engine oil temperature sensor. The temp is what determines how long they stay on. When the light goes out the glow plugs may still be on. Anything below 30 deg F the motor should be pugged in to keep the block warm and ensure easy startup.
