1980 f 250. spindle problem
Old Feb 9, 2004 | 07:07 PM
reddragon80928's Avatar
reddragon80928
i have an 80 f 250 and the outer wheel bearings has welded itself to the spindle.it has the king pin instead of ball joints.i have taken the whole suspension off ,the i beam spindle rotor and axle assembly off.took a trip to the junk yard today and was told i could only use a certian year of truck,found an 86 with everything i need and was told i couldnt use it,does anyone know why? need the truck badly.i had thought about converting it to 4 wheel drive,if i do what year of truck do i need to use,is is possible?if nothing else can i use the 86 parts.
