JUST TO MENTION: After reader the codes with one of those wicked cool star reader tools, i cleared the codes and drove 30 more min and No check engine light!
As I recall the Check Engine Light will only come on for this fault after the engine is at full operating temperature. As I see you are in NH and I'd assume it takes a little while to get to temp up there, if it were summer you'd see it more. As for the location of the sensor, I can't help I had the 4.0. I do however think it only cost about $20 and wasn't too hard to replace, just a threaded connector and a vacuum line.
OK feeling really stupid but what does DPFE stand for, and where is the sensor, I realize its an emissions thing, but im not in the know about this one
Im willing to try anything i can do on my own rather than paying some one so bring on the DPFE sensor!!
I believe your EGR sensor/valve is on the back of the engine against the firewall on the passenger side. Before changing your sensor, I would clean the EGR valve first, they get nasty dirty with deposits and my EGR valve got clogged and stuck...setting off a CEL.
All I did was pull off the valve, clean it with a lot of carb cleaner and it fixed my problem. Buy a Haynes repair manual, it will show you the way. It is an easy fix....the hardest thing is getting to the bolts to take the valve off.
