1978 - 1996 Big Bronco
2 inch lift
Old Feb 9, 2004 | 04:29 PM
Broncobigtire's Avatar
Broncobigtire
2 inch lift
I have found a 2 inch suspension lift for my bronco and just wanted some more info. It comes with 2 new front coils and 2 rear add-a-leafs. My question is what else i would new. It said oversized camber/caster shims are required. Anyone know where to get them and how $$? Thanks. This is the starting point of my build 2inch lift, 32's, 3.73 gears, custom front and rear bumpers, exhaust, intake!!!!
Old Feb 9, 2004 | 07:18 PM
Black Ford XLT's Avatar
Black Ford XLT
lift
When installing a lift for my 92 bronco(leveling lift)(ordered from jc whitney)(which is a superlift), when i had it installed this kit came with caster camber bushings which are stated in degrees.Mechanic i had to install it had to order a different set of them(degrees) to do a front end alignment.This is very critical for the right alignment. Most four wheel shops carry them . i guess u can do a search to see if any one has had luck fiding them in here .Goodluck TR
