Excursion mirrors on a F350 SD
Old Feb 9, 2004 | 02:43 PM
MTMike's Avatar
MTMike
I put a set of power heated Excursion tow mirrors on my 2000 F350 SD. I like them a lot better than the mickey mouse ears I had.
How does the Excursion turn on the mirror defrost?
In the F350, there is no electrical defroster to tie the derfost power into. I think my mirror adjust switch is bad - I was wondering if the Excursion switch would fit the F350 and if it has a switch for the heated mirrors.
thanks,
mike
Old Feb 9, 2004 | 05:05 PM
Landyot's Avatar
Landyot
The mirror heat function is operated by the same dash-mounted switch that simultaneously energizes the rear window defroster.
Old Feb 9, 2004 | 05:22 PM
MTMike's Avatar
MTMike
Thanks for the reply - I was afraid someone was going to tell me that. Guess I improvise a switch.
mike
Old Feb 9, 2004 | 05:44 PM
Landyot's Avatar
Landyot
Why add another switch? If it were up to me, I'd determine which wire "feeds" the rear defroster, then tap into it for the heating elements in the mirrors. It's called the K.I.S.S. principle. Any time you need the mirrors defrosted, you'll also need to defrost the rear glass. Your choice.
Old Feb 9, 2004 | 06:35 PM
MTMike's Avatar
MTMike
I agree with K.I.S.S. Unfortunately, The F350 does not have an electronic defroster installed. Maybe the models that don't have a sliding rear window do but mine doesn't.
mike
Old Feb 9, 2004 | 06:38 PM
Landyot's Avatar
Landyot
Ahhh ... NOW it makes sense. Please excuse me for not remembering you were talking about an F350.
Old Feb 9, 2004 | 07:44 PM
brwolfjr's Avatar
brwolfjr
on the newer superduties, the heat is on all of the time. I just installed the TT with light and heat.
Old Feb 9, 2004 | 08:14 PM
MTMike's Avatar
MTMike
That is good to know - maybe I don't need to install a switch. It would certainly be simple to put power to them all the time.
mike
Old Feb 10, 2004 | 05:04 AM
psdwanabe's Avatar
psdwanabe
The thing is many have complained (f series) that they don't want the heat on all the time. So they rig up a switch. If your already into it, this would be the best time to add a switch.
