Sponsored by: Real Truck
Brake controller mounting
Old Mar 27, 2002 | 10:57 PM
weldman's Avatar
weldman
I am wanting to install the Tekonsha Prodigy (dad went out and blew his days wage on it) this weekend and was thinking of installing it beneath the 'junk hole'. Is there anything behind the plastic panel that I shouldn't drill into?
Matt
Old Mar 28, 2002 | 12:17 AM
SVO's Avatar
SVO
weldman ,
As well as I remember there is nothing there if you dont drill deep but to keep from drilling you can go to Radio Shack and get a male and female 6 prong plug kit and take your harness and make you a seperate harness for your brake controller the new controllers work in any position, I just lay mine in the floor board on the hump when I am done, I just unplug it and put the wire up under the dash and put the controller on the console and they are no unsightly holes hope this helps out.
SVO
Old Mar 28, 2002 | 09:21 AM
weldman's Avatar
weldman
Thanks for the hints SVO! My dad tells me that the prodigy has a quick disconnect system on it already, so I'll see if I can do something as you are describing! (I haven't seen the thing yet)
Matt
Old Mar 28, 2002 | 10:26 AM
Jim F350's Avatar
Jim F350
Post Brake controller mounting
Since you list a 2002 F250 in your signature, I'm not sure what truck you are installing the controller in. If it is the 2002 F250 and since you list "cmpr" in the options, it should have come with a brake controller pigtail (connector with 5 wires). Under the dash you will find a plug (not too accessable) to plug it into. Just follow the schematic with the pigtail (the big overall schematic , not the little pigtail drawing) and the one with the controller to match the necessary wires (not all are necessary, depending on the controller). I just did my F350 last weekend and it took about 1/2 an hour to do. On my 350 there was a lot of space behind the panel under the junk hole and that is where I mounted mine.
Jim
2002 F-350 Lariat 4X4 Crew PSD 3.73
Old Mar 28, 2002 | 10:37 AM
super_duty_dan's Avatar
super_duty_dan
I am not familiar w/ the prodigy controller, but isnt it unsafe to mount your brake controller in a spot you cant reach if you need to manually put the trailer brakes on? With that in consideration, i found no other spot to mount my brake contoller beside drilling into the dash under that tray hole thing.
Old Mar 28, 2002 | 10:42 AM
weldman's Avatar
weldman
Yes, you do indeed have to have the thing hard mounted to apply the trailer brakes in emergency. I most likely will mount it below the hole in the dash (2002).
Thanks!
Old Mar 28, 2002 | 12:18 PM
Dave_C's Avatar
Dave_C
[updated:LAST EDITED ON 28-Mar-02 AT 01:19 PM (EST)]Why not mount it *in* the hole? I did, looks great, is within easy reach and doesn't get bumped when getting in/out.
I mounted the Progidy with 3 strips of velcro attached to the top of the hole. I drilled a 5/16" hole int he back, upper left corner of the hole. Big enough to feed the wires through, but not the whole plug. The hole is small enough and located where it can't be seen from the sitting position, even if the controller is removed.
Take a look:
http://prod.bsis.bellsouth.net/coDataImages/bellsouthpwp/Groups/26/26404/folders/12853/69019Image004.jpg
Later,
David Cole
Old Mar 28, 2002 | 12:57 PM
blynam's Avatar
blynam
I used double sided tape to mount mine on the removable panel. See [link:http://www.rvtrader.dingojunction.com/SD02/F350/Index.asp#CB|Brake controller mounting]
Bill in Cincinnati
Old Mar 28, 2002 | 05:31 PM
plumr's Avatar
plumr
I mounted mine the same place Dave_C did that junk hole is no good for anything anyway and its a great place for it...
Old Mar 28, 2002 | 08:59 PM
GRUMPY_ FD's Avatar
GRUMPY_ FD
So did I mounted it in that junk pocket looks great and its out of the way.And even leaves enough room for that dang cell phone.
Old Mar 30, 2002 | 01:46 AM
Edmo's Avatar
Edmo
I mounted my prodigy on my dash under the junk hole with drill holes, screws and the whole bit... No problems. I did get some of that plastic wire protective tubing to run my wires through to dress them up a bit. worked out nice.
Edmo
Old Mar 31, 2002 | 08:45 PM
4x4x4x4's Avatar
4x4x4x4
I needed to use my trailer yesterday.I didn't want to do any drilling in my dash.I removed the two screws that mount the diagnostic plug and used one of the screw holes and a strip of velcro to mount the controller bracket,with an extra hole I placed in the center of the bracket.The diagnostic plug is now just above and behind the removable panel and is held there with a wire tie.It took about ten minutes.I may remount it later,but it isn't bad at all considering the time spent.
Old Apr 1, 2002 | 07:12 PM
weldman's Avatar
weldman
Thanks for all the help guys! I did get it mounted, finally! I used the quick disconnect mount just because I thought that it looked better and for the feature it offered.
I mounted it under the junk hole because I like to throw my wallet or cell phone in there.
Here's a pic!
http://members.rogers.com/mattjibb/prodigy.jpg
Old Apr 1, 2002 | 08:29 PM
4x4x4x4's Avatar
4x4x4x4
