Aftermarket Products
Sponsored by: Worksport
Body Lift
Old Feb 9, 2004 | 04:06 AM
peppy's Avatar
peppy
Body Lift
How high can you go with a body lift before you have to start extending stuff like the steering colum and throttle linkage? Thinking of doing a body lift in the next couple weeks, after I put on the new springs. Never done a body lift. I'm sure it will be another 6 pack adventure in the barn.
Old Feb 28, 2004 | 11:54 AM
FL. Ford's Avatar
FL. Ford
3 inches and its fairly easy with someone to help you out with it.Just loosen all bolts and install the lift one side at a time.
Old Feb 28, 2004 | 12:43 PM
FL. Ford's Avatar
FL. Ford
Let me clarify my previous statement .Loosen all the bolts(do not remove the nuts).THen remove the nuts and install the lift spacers and new hardware, that comes with the kit, one side at a time.
Old Feb 28, 2004 | 11:36 PM
jessfactor's Avatar
jessfactor
do you need an alignment after a body lift? also what kind of gas mileage do you get after it. i know the increased air resistance has to do something negative.
Old Mar 1, 2004 | 12:14 AM
FL. Ford's Avatar
FL. Ford
AN alignment is not needed since you are simply lifting the body from the frame . You do catch a little more wind underneath.
