timing problems
Old Feb 9, 2004 | 12:13 AM
o0haco0o's Avatar
o0haco0o
timing problems
i have a `74 Ford F-100 2WD with a 5.9L 360. and i know the timing is off but i cant time it correctly because the harmonic balancer is really rusty. is there any special chemicals or anyway to get the rust of because i cant afford to buy another harmonic balancer.
Old Feb 9, 2004 | 04:58 AM
ClodsFe's Avatar
ClodsFe
P.B. Blaster and wipe almost immediatley. May have to do this a few times. Some real fine emry cloth might be in order but be carefull not to sand off the marks.
Old Feb 9, 2004 | 11:10 AM
o0haco0o's Avatar
o0haco0o
thx man, i just bought a brand new can of that the other day. ill try it out.
Old Feb 9, 2004 | 01:52 PM
Mike G's Avatar
Mike G
Also, you can take a white crayon to the timing mark you want to use (ie 6 BTDC).
--Mike G
Old Feb 10, 2004 | 09:24 AM
fordpilot2's Avatar
fordpilot2
There is a fluid point pen available with a yellow ink made
especially for marking on metal. Mine is called a
Super Met Al Marker. Works good on timing marks..cheap and
available at most part houses.
