Sponsored by: Real Truck
np271 transfer case specs
Old Apr 2, 2002 | 08:27 PM
Texasj10's Avatar
Texasj10
Does anyone have any specs on the NP271 transfer case that is in some F350's? It is mentioned in the latest Four Wheeler magazine and I am curious how big, heavy, and strong this might be in relation to a NP241. Any help or guidance would be appreciated.
Old Apr 3, 2002 | 08:45 AM
Monsta's Avatar
Monsta
Sit. Stay.
Well, I share what I know. (Which isn't much at all...)
The
2 Means 2-speed.
7 Means case strength. 7 being the highest
1 Means Mechanical shift. 3 being electronic shift
Knowing NOTHING about the NP241 but it's numerical designation, I'd say the NP271 has a stronger case.
The NP271/273 is a chain drive X-fer case. Is the NP241? Or is it gear driven?
Old Apr 3, 2002 | 09:01 AM
NoMo's Avatar
NoMo
Several months ago there was an article in Four-Wheeler about transfer cases. They did a comparison of the ones used by new trucks and the SD case is was the strongest one available in a production/consumer truck. Of course you can buy bigger/stronger ones, but it'll be an aftermarket unit.
Old Apr 3, 2002 | 09:05 AM
FortyFords's Avatar
FortyFords
It is also used in f250's not just f350's
I have one in mine
Rich
Ford Trucks Built Tough!
not with rocks
Watch out "X" Mayor of Truckville
Old Apr 3, 2002 | 10:16 AM
J.C.'s Avatar
J.C.
[updated:LAST EDITED ON 03-Apr-02 AT 11:19 AM (EST)]----------------Np241----------NP241HD-----------NP271/273
Max cap. tq.---5555 lb-ft-----5555 lb-ft------7890 lb-ft
weight lbs--------80-------------100------------120/123
oil cap. pints---5.0-------------6.5---------------4
The 271/273 is used in the ford super duty line F-250 to F-550 and dodge is switching over from the 241/241HD to the 271/273 in their newly designed heavy duty trucks.
Old Apr 3, 2002 | 08:03 PM
Texasj10's Avatar
Texasj10
Thanks guys. The information you provided has helped. Any idea as to the diminsions of the case? I want to drop one of these into a 1979 F350, but I am concerned about frame clearance. I can adapt it to the tranny but still have concerns. I notice on the late model F250 and F350's that the front differential has been moved way off to the side with just enough room for the spring to sit on top of the cast flange. It is at least 12 inches closer to the frame than on my truck. Did they do this to line up the drive shaft to the NV271? IF so, I think that the 271 might stick out too far to the side and hit my frame. Sorry for the ramble.
Old Apr 3, 2002 | 11:12 PM
FTE Ken's Avatar
FTE Ken
nogo73
Offroad & 4x4
Jul 28, 2017 01:11 AM
chrisfp178
Mar 26, 2017 07:57 AM
Dantylr1964
Jan 7, 2017 06:45 PM
dabeef
Apr 20, 2016 04:47 PM
TonyG
Feb 11, 2002 03:51 PM
