General Automotive Discussion
Loose Sway Bar
Old Feb 8, 2004 | 07:29 PM
dmancine's Avatar
dmancine
Loose Sway Bar
My daughters 99 Mazda Protege has been making a clunking sound when it hits a bump. She had it at the dealer for another problem and they heard the clunk and siad it was a loose sway bar. They recommended that it be replaced. My question...What are the consequences of not replacing it?? Is is safe to drive?
Old Feb 8, 2004 | 08:57 PM
bosshoss's Avatar
bosshoss
The sway bar is more to help the car handle in turns and keeps the car steady. Unless something is broken on it like a link bolt or mounting bracket, it should not be a bad problem. But if your like me, any problem when involves ones childs safety is a concern. You might be able to just replace a bushing or link, not sure on this car. When you have the oil changed, have them do the car look over thing, its free at most shops with a general service.(more money for the shop when they can find things) Let us know later. I think your car has links that bolt to the struts, and they have been known to come loose. Good luck.
