Ed's 54 Rebuild
#32
Hey John. Who keeps screwing with my signature? I know there are rules about non ford post but there are none about none ford signatures or there would be very few signatures.
Never Mind!. I found the rule but I still cannot beleive it. Ed
#33
Well I am home and this time no new toys. Now it is time to get back to the rebuild. I was looking at a FE390 and am now not looking at it. In fact now I am looking at that 292 I already potentially have. I have reconsidered the mamoth engine even though I had it so cheaply. It just does not fit my idea of a good all around driving truck.
BTW guys you would not have beleived all of the old fords and chevys I saw that were in good shape in Venezuela. So cool. Ed
#38
Well today I got both of the runnning boards off and both rear fenders. To find out what motor and heads I had in the truck I pulled the exhaust manifolds off and found out that I had a 272 ECG block and a ECG-D set of heads. Looks like I will be getting a new motor after all. I finished spraying the front fenders and other front fender well bolts to remove tomorrow. This should be easy. So far I have found only small rust holes that can be easily repaired. Ed
#39
Hi Ed, I don't know what's in your signature that causes the censors to activate. I do know that they try to eliminate anything that would cause arguments or hard feelings. So, it may be in the interest of good feelings and harmony that your signature is being changed. So, try another one. How about "International Ford Inspector." You can also email Kenny and find out what's happening and why. Good luck, John
#40
#41
Arggggh! Front fenders and doors took me 2 freaking days. So much for spraying them with a lube. Who the heck designed this truck. You have to take bolts out of the cab to get the fender off. Doors were simple though and all else looks good for coming apart this weekend. Should be down to the frame by Sunday. Not bad for 2 broken weeks work. After looking at the wiring I think it is simple enough to do myself. Advice to all that rebuild. Buy a nut splitter, a dremel and a 4.5" grinder. You will need all to get those damn fasteners out of various places. Oh yeah wear gloves when you do it. The cuts and bruises makes it look like your wife is beating you for your effort.(She really is but I am blaming it on my truck) Ed
#42
on
Ed,
Ahhh feel your pain!
When I removed the front sheemetal on my F-3, nearly every nut and bolt holding it on wrung off. That comes with the territory on these old trucks and is one of the "grand" things about living in the snow and salt. I sprayed mine with WD40 too and it did absolutely nothing...
#43
#44
FYI I have found that the WD-40 doesn't work that well as a penetrating oil. Try using PB-Blaster. Spray it on and let it soak over night. Then spray it again before you start it. That stuff seems to really work its way through. My grand father was a machinist and tried to teach me some of the tricks he knew. The one thing that is very hard to teach is patience! I still don't have a lot of that.
#45
That is what I am using and also miracle oil spray. My garage smells like insecticide with the PB spray. It works most of the time but some of the nuts have already dissolved by at least one size and have to be cut off. At least so far all is repairable and does not require replacement other then the chrome and rubber items. Ed
