Help on 351M or W ??????
Old Feb 8, 2004 | 10:52 AM
pg409's Avatar
pg409
I just aacquired a 79 Ford Econoline Van as a donor motor
and transmission for our 54 Ford Station Wagon.(passenger)
I'm not sure if I have a 351M or a 351W engine. How can I
tell??
If it is a 351M does it have the same motor mounts as a
small block and do all the transmissions, c4 c6 and aod work
with this engine? In other words, does this engine bolt in
where a 302 or 351W would go??
THANKS
Keith
Old Feb 8, 2004 | 10:54 AM
JamesAtXtra's Avatar
JamesAtXtra
351W has the thermostat housing on the front of the intake. 351M has the thermostat on the top of the block in front of the intake.
Old Feb 8, 2004 | 10:58 AM
JamesAtXtra
351m has different trans mounting (same as 460) and different motor mount bosses (3 bolts going into side of block) 351w has 2 bolts going straight up beside oil pan just like 302 and uses same mounts as 302.
Old Feb 8, 2004 | 11:34 AM
monsterbaby's Avatar
monsterbaby
another way to tell is a 351m has 8 bolts in each valve cover, and a 351w only has 6. The 351m will NOT fit inplace of a 302 or 351w without major changes
Old Feb 8, 2004 | 01:34 PM
packlet's Avatar
packlet
The 351M was never put in the econoline vans, afaik. The 400 was, but only from 1980-82.
In '79, it might have had a 351W (engine code H) or a 460 (engine code A).
Old Feb 8, 2004 | 01:58 PM
pg409's Avatar
pg409
Many thanks to all who replied. I just checked the vehicle
and we definitely have a Windsor motor here.
THANKS
Keith
Old Feb 8, 2004 | 06:19 PM
Torque1st's Avatar
Torque1st
Posting Legend
We have a full size van forum here also that may have application info.
