Mass Air Kits
Old Feb 7, 2004 | 10:30 PM
COBRAjrb's Avatar
COBRAjrb
Question Mass Air Kits
hi ive got an 88 bronco with a 351w efi. i found a mass air kit at summit raceing for 689$ does any body no where i could pick up a cheaper one? but is it possiable to hook up an kna intake filter if you have mass air? or would that mess it up? thanks
Old Feb 8, 2004 | 04:13 PM
EPNCSU2006's Avatar
EPNCSU2006
$600's are about the best you will be able to do with a kit. K&N shouldn't be a problem with the mass air. It should bolt directly to the air meter in the kit, just find the right size. Another option (more expensive) would be to get the K&N kit for a Ford with factory mass air. It should have the adapter to bolt to the flange type mass air meter, or where the airbox connects to the intake hoses on the conversion kit.
Old Feb 8, 2004 | 05:06 PM
COBRAjrb's Avatar
COBRAjrb
cool man rock on thanks for the info im glad after that i can still hook up kna
