Sponsored by: Real Truck
Rancho RS9000 Remote Install Question
Old Feb 16, 2002 | 07:05 AM
rocket02's Avatar
rocket02
Old Apr 5, 2002 | 09:38 PM
PeteC's Avatar
PeteC
I just got a set of RS9000 shocks with the remote control. I have 2 questions:
1. The instructions call for "Lithium Grease" to lube the o-rings. I have some Solder Seal Gunk brand spray lithium grease. Is this the right stuff?
2. Any suggestions on how to provide sufficient slack in the pressure lines to the shocks?
Any additonal suggestions on the installation are appreciated. Thanks.
Pete
99 F350 CC V10 2WD LB Auto
Old Apr 7, 2002 | 11:31 PM
Outpost22's Avatar
Outpost22
Pete,
I wish I could be of more help, but mine were installed by a dealer. It is my belief that your lithium grease should be fine if thats what it calls for, but I always thought that petroleum grease would eventually break down rubber products. In irrigation work we use a lube to "grease" "ring-tight" gaskets that is not petroleum based so it won't rot the rubber gaskets. "Crisco" even works in a pinch
As far as the "slack" issue goes, mine are "zip tied" down the shock with the shock at full extension. Since I can't see what happens when I'm driving:+ I assume the lines "gap" slightly when compressed.
This is probably of little help, but I didn't want your post to go unanswered
Old Apr 5, 2003 | 10:20 PM
Buzzard_Wing's Avatar
Buzzard_Wing
I am also curious about the answers. Some installations (all??) are sold as easy... till you try to figure out how to get something into the cab or what not.
Trying to decide on shocks to replace my factory set (yes on a 95!)
I am leaning towards RS9000x, but rarely carry a load and they are a bit pricey....
Old Apr 6, 2003 | 10:31 AM
Outpost22's Avatar
Outpost22
If you're rarely carrying a load, then you are probably "overkill" with 9000's. Their main attribute is adjustability, mostly for loads. You would probably have them set at one of the softest settings and leave them there. No need for a controller. Just manually adjust them if you load it heavy. Then, it is an EASY install as opposed to the "controller work
