Sponsored by: Innova
Custom Box Dimensions
Old Feb 7, 2004 | 06:20 PM
Munkey's Avatar
Munkey
I took some measurements off my truck today to see what's the biggest box I can fit behind my drivers seat, with the x-cab jumpseat folded up.
The dimensions are:
15W x 16D(1) x 13D(2) x 15H
Based on y'alls past expierences, what are my options with a box this size??
Old Feb 8, 2004 | 01:08 PM
brianas's Avatar
brianas
inside a relatively small interior like that of a truck you will want
to use a slightly larger enclosure for your woofer(s) if possible
The woofers tend to sound real 'punchy' if not
also you some acoustic damping inside the box
I would recommend a sealed enclosore box with a single 12"
woofer
With the dimensions you took you will get about a 1.45cu ft.
enclosure-subtract woofer displacement .110cu ft.==1.34cu.ft
Find the woofer you plan on using and look up the recommended
enclosure volume in cu ft.--with a sealed enclosure you can give or
take about 10% of the volume --In your case I would go with the 0-10% greater than recommended which will lower your resonant
Frequency and lose some of the punchy sound--deeper bass
I just built a sealed enclosure for my extend cab f250
for a 12" woofer--it called for 1.0 cu ft.---I built the box at
16"H--16"W--10"TD--13"BD with woofer this yielded 1.10 cu ft.
sounds excellent --fits like a glove
Take your dimensions and subtract about an inch in the depth
and you will be in the ballpark for a 12" woofer
also note if you plan on sealed box--they generally sound better
firing up or to the rear of the xtend cab
post if you need more info
g/l
Old Feb 8, 2004 | 05:31 PM
Munkey's Avatar
Munkey
Thanks for the reply brianas, a 12 is what I was looking to run. I looked at some measurements on some pre-made boxes and my measurements are +/- 1" off from theirs.
Old Feb 9, 2004 | 09:02 AM
PrPlayboy's Avatar
PrPlayboy
Just make sure when calculating dimensions to pay attention to inside dimensions and outside dimensions. It's very easy to make a box 1.5 inches to big. I did it on my first box and nox I have a box in my Explorer that fits perfect with not even 1/4" to spare any where.
