Two piece drive shaft
Old Feb 7, 2004 | 01:31 PM
ncl's Avatar
ncl
Hey guys just wonderin why my truck has a two piece rear driveshaft and others I see has only one piece. My truck info is down below and the gvwr is 6500lbs. Just wondering if anyone knows the answer to this question. Oh yeah it has a C6 and a np205.
Old Feb 7, 2004 | 02:10 PM
LxMan1's Avatar
LxMan1
What wheelbase is it?
Old Feb 7, 2004 | 02:15 PM
ncl's Avatar
ncl
Sorry about that it is a regular cab, long bed pretty standard I think it is 133". Also how about finding out how much suspension lift it has I need to know want to get new C bushings it has
2 3/4" drop brackets on the radius arms not sure whether it has a 4 or 6in lift.
Old Feb 7, 2004 | 11:19 PM
Torque1st's Avatar
Torque1st
Posting Legend
The driveshaft span is determined by the diameter of the shaft, the type of steel and the rpm's etc. They pop all of that into some fancy formulas and out pops a max distance. Some trucks then take a three piece shaft. Your shaft with the carrier bearing is considered a three piece shaft because of the spline joint.
Old Feb 9, 2004 | 11:54 PM
toyotaguy's Avatar
toyotaguy
heres how it goes if you make the drive shaft too long it starts a whip. no matter how ballanced it is it will shake like its gonna come out. its nothin like you ever heard in your life. materal and size to take a part in it but its mostly a length.
Old Feb 10, 2004 | 12:09 AM
Torque1st's Avatar
Torque1st
Posting Legend
I can get you the formula if you want it but it would be useless without all kinds of info on materials and bearing structures. I have had to design power transmission and motion control shafts in machines. When a shaft reaches it's critical rpm it will sound like all hell is breaking loose. The driveline shops have tables they use that simplify things a lot. The tables make certain std assumptions about materials that simplify things.
Old Feb 10, 2004 | 11:03 AM
loudfords's Avatar
loudfords
I would like the formula if it's not too much trouble. Might come in handy if I need to design something that is shaft driven.
Old Feb 10, 2004 | 12:11 PM
Torque1st's Avatar
Torque1st
Posting Legend
Here are some sites that have the software to do it:
http://www.hexagon.de/wl1_e.htm
http://www.kisssoft.ch/doku/KISSsoft...ight-shaft.pdf
http://www.romaxtech.com/software/da...prog_rxdyn.pdf
http://www.mitcalc.com/en/pr_shaft.htm
http://www.geocities.com/brybolt/software.html
This one is of interest to automotive enthusiasts:
http://www.raceshafts.com/critical_speed.htm
You can also find the information in Machinery's Handbook and the Handbook for Mechanical Engineers.
