1978 - 1996 Big Bronco
Axle differences
Old Feb 7, 2004 | 01:18 PM
MustangGT221's Avatar
MustangGT221
Axle differences
Is there any difference between a 78 and 79 front axle? Is the differential on the left side?
Are they different than the early bronco front axles?
Old Feb 7, 2004 | 08:24 PM
BroncoRoadKill's Avatar
BroncoRoadKill
The 78-79 are the same dana44. Fords all have the pumkin on the drivers side.
The early broncos had the same axles, but they were chopped a little shorter.
Old Feb 8, 2004 | 07:07 AM
MustangGT221
Shorter as in the width...
I heard somewhere that the axle shafts on the early bronco were a little smaller..is that true?
I would have asked in the axle forum, but I figured it would be better here since it's really specific
Old Feb 9, 2004 | 06:41 AM
RTM's Avatar
RTM
I can't recall all of the info on this but I had looked into it at one time. The EB 44 axles can accept and people do use the full size 44 axle shafts so that they can run the stronger u-joint. The outer part of the axle I think has something to do with the groove for the retaining clip. I am sorry I don't know more. You may try the EB forum. I am sure someone there will be able to help you. I sold all of my EB stuff and haven't been following it any more. I still have two sets of full size 44 axles shafts lying around if yoiu need a measurement.
