351 installation problem
Old Feb 7, 2004 | 12:28 PM
tnwalker01's Avatar
tnwalker01
HELP! My son and his friends are trying to replace a 400 with a 351m in a 79 f150 w/ automatic trans. The converter turns freely before the trans is hooked up, the engine turns before hook up. The studs on the converter line up. Everything goes together but the engine won't turn once the trans is hooked up. We're missing some detail but don't know what. Any help would be greatly appreciated. Thanks in advance.
Old Feb 7, 2004 | 12:33 PM
monsterbaby's Avatar
monsterbaby
Are you sure that the convertor is into the pump correctly, if it is not all the way into the pump gear then when you pull it together, and bolt it up you would be binding it up, and probably breaking the trans pump
Old Feb 7, 2004 | 01:22 PM
tnwalker01's Avatar
tnwalker01
They think it is connected to the pump correctly. Would the converter turn if it wasn't?
Old Feb 7, 2004 | 01:39 PM
scroob's Avatar
scroob
It would cause a bind.
There are 3 things that have to engage - the pump, and the 2 splined shafts. Getting the second (and last) splined shaft to engage can be difficult sometimes. Also, it's easy to overlook.
Put your hands against the converter, and spin it back and forth while at the same time rocking it up and down and from side to side. When you feel that last shaft engage, you'll know it.
Old Feb 7, 2004 | 02:36 PM
tnwalker01's Avatar
tnwalker01
I think that's the problem. We've been able to get it to engage two times but can't get the third. We've tried rocking back and forth and up and down with no luck. Tried it with the trans in neutral and in gear. Any suggestions?
Old Feb 7, 2004 | 02:50 PM
willd's Avatar
willd
If you already bolted it together mis-match you may have broken something in the pump.
The best way I ever found was to get the engine away from the trans completely. Then sit down in front of the converter and spin it slowly while rocking it up and down and pushing in. Once you get it in right when you bolt the engine up to the housing there will be a small gap between the converter and the flex-plate. If you don't have this play something isn't right. The bolts have to pull the converter out several thousandths of an inch till it is flush with the plate.
Take the converter all the way out, then put it back in and spin/push/wiggle until you count 3 clunks. That's the only way to know for sure.
Old Feb 7, 2004 | 08:13 PM
tnwalker01's Avatar
tnwalker01
Thanks everyone for the help. We may have jammed things up in the converter. Still can't get that third "clunk" after working on it all afternoon. Guess we'll go at it again in a day or so. Again thanks for all the input.
Old Feb 7, 2004 | 10:09 PM
Mark6728's Avatar
Mark6728
Re: 351 installation problem
I have installed motors with automatic tannys and not have the torque converter fully seated onto the input shaft on the tranny it will still bolt together just real hard like i suggest seperating the engine and tranny and try spinning the torque converter will pushing it towards the rear of the truck
Old Feb 8, 2004 | 02:26 AM
Purely Ford's Avatar
Purely Ford
The inside of the transmission isn't the only thing that could be damaged by now. The convertor may have damage as well. Better pull the engine and transmission apart and inspect the convertor, flex plate and the pump in the transmission.
I made this mistake on an engine swap once and had to replace all of the above parts. Consider yourself lucky if the bellhousing is still all in one piece.
